Noobie here! - Need Suggestions On Rim/Tire Size For A 88 Accord Hatchback
Old Apr 30, 2008 | 05:44 PM
tigers77's Avatar
Default Noobie here! - Need Suggestions On Rim/Tire Size For A 88 Accord Hatchback
I'm new to the Honda scene after driving VW's and Beemers for a long time. Anyways, I picked up a <U>FREE</U> 88 Accord 2 door hatchback in decent shape body and engine wise with 190,000+kms.
A few rim/tire questions for you experts:
1) What is the bolt pattern on this make and model?
2) What is the offset? Currently it has some rusty steelies and I can't find any stampings on them.
3) Currently has 185/60/14 all season tires. Is this the stock size?
4) If so, if I upgrade to 205/40/16 tires will it rub if I use Eibach Sport "1.5 lower springs on Koni shocks/struts?
Thanks in advance for any input!
Old May 1, 2008 | 09:24 AM
tigers77's Avatar
Default Re: Noobie here! - Need Suggestions On Rim/Tire Size For A 88 Accord Hatchback (tigers77)
bump
Old May 1, 2008 | 11:56 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tigers77 &raquo;</TD></TR><TR><TD CLASS="quote">I picked up a <U>FREE</U> 88 Accord 2 door hatchback</TD></TR></TABLE>
Can't beat that price!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tigers77 &raquo;</TD></TR><TR><TD CLASS="quote">1) What is the bolt pattern on this make and model?</TD></TR></TABLE>
You can measure it yourself. Use the instructions in the FAQ topic stickied at the top of this forum.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tigers77 &raquo;</TD></TR><TR><TD CLASS="quote">3) Currently has 185/60/14 all season tires. Is this the stock size?</TD></TR></TABLE>
No. Stock sizes:
1988 Accord Hatchback - 165/-13 (80 is the default aspect ratio)
1988 Accord LX Hatchback - 185/70-13
1988 Accord LXi Hatchback - 195/60-14
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tigers77 &raquo;</TD></TR><TR><TD CLASS="quote">4) If so, if I upgrade to 205/40/16 tires will it rub if I use Eibach Sport "1.5 lower springs on Koni shocks/struts?</TD></TR></TABLE>
On any of these models, if you get 16" wheels, you should be getting 205/45-16. The size you mention is too small. And the outer diameter of 205/45-16 is about the same as stock; although I haven't tried it on that car, as a general rule, you won't rub with the stock outer diameter and a 1.5" drop.
Old May 2, 2008 | 06:34 PM
tigers77's Avatar
Default Re: Noobie here! - Need Suggestions On Rim/Tire Size For A 88 Accord Hatchback (nsxtasy)
thanks for the input!
Old May 3, 2008 | 09:07 PM
turabaka's Avatar
If you want to get some really good info on that car go to http://www.3geez.com there's plenty of good stuff there. I've got an 88 Accord hatchback too, and the guys over there are really helpful, and cool.
z395civic
Jul 5, 2009 10:25 AM
ombl4
May 8, 2007 01:19 PM
velocity
Nov 19, 2006 10:44 PM
blackpearlv6
Apr 21, 2006 11:42 AM
eg686
Sep 2, 2005 03:15 AM
