CRX Rear Wiper Delete HOW-TO
Old Apr 30, 2008 | 02:28 PM
UfoTofU's Avatar
Default CRX Rear Wiper Delete HOW-TO
Disclaimer :
Yes I know my car is crazy dirty and needs a paint job.
I have a 91 CRX DX. I am not sure if this will work for other years so as far as I know the following will only work on this year / model.
I skipped getting pictures of some of the steps but once you are there doing it it should make perfect sense.
Let's start by removing the rear wiper. You will want to flip up the cover exposing the nut that holds the wiper itself on there, remove it. Pull up and the wiper will be free.
Once you remove the wiper itself there will be a piece of rubber plastic that you have to lift off and expose a large flat nut underneath. You will just need an appropriately sized socket. For now ignore the large flat nut that is exposed, we will remove this later.
Now remove the rear brake light cover by turning the little plastic piece and expose the rear brake light. I don't think that it is necessary to remove the brake light assembly but I did just to get it out of the way and take away any risk of damaging the light assembly. The two bolts hold it in, be sure to disconnect the wire plug.
Remove the plastic garnish that goes around the inside of the rear hatch window so that you expose the underside of the wiper motor assembly. There will be 4 plastic screws to remove, this is a picture of one of them, the rest are identical. This garnish piece fits into a couple of little slots that attach it to the bottom garnish piece, do your best not to break these or the clips holding it on. It may take some wiggling and prying to get it loose.
Now the wiper motor assembly will be exposed. Disconnect the wiring plug. Three bolts hold it in, remove them. In this picture I had already removed 2 of them.
Once these bolts are removed you can then go back to the outside of the hatch and remove the large flat washer. Be sure to hold the motor with one hand while you remove this nut.
Now to fill the hole. There are a couple options that I know of and one that I wasn't interested in involved welding. The other option was to plug it with a rubber grommet. I stole mine from my fire wall behind the right front wheel.
Pop it out and fill up the hole left behind. Stick it into the hole where the wiper was and you are finished. You may want to spread a bit of silicon on the grommet or around the hole to make a better seal.
The finished product :
Modified by UfoTofU at 4:22 PM 4/30/2008
Old Apr 30, 2008 | 02:57 PM
STREETWERKZ's Avatar
Default Re: CRX Rear Wiper Delete HOW-TO (UfoTofU)
been there done that.
except, i just bought a new grommet from honda.
Old Apr 30, 2008 | 03:03 PM
senna 1's Avatar
Good to know. Looks straight forward.
Old Apr 30, 2008 | 03:21 PM
UfoTofU's Avatar
Default Re: CRX Rear Wiper Delete HOW-TO (senna 1)
It was actually pretty damned easy. Only took me about 20 minutes including taking the pictures that I took.
I never really liked the looks of the rear wiper and never ever used it so I decided to take it off of there.
Old May 5, 2008 | 08:18 PM
UfoTofU's Avatar
If you happen to do this yourself post up your pics here so other people can check it out.
Also let us know what year / model you did it on and if there are any variations on the procedure.
Old May 5, 2008 | 08:34 PM
Voodooboy520's Avatar
Man I should do this, I never use mine and it looks ugly. Plus all the paint is comming off.
Old Jun 9, 2008 | 05:07 PM
i_VTEC's Avatar
Default Re: (Voodooboy520)
I just did it and it works, But i broke one of the tabs that holds that plastic piece in. I swear you have to be hella careful when removing plastic parts from an EF because I don't think i have ever removed a plastic piece from my CRX where i didn't break something haha.
Old Jun 9, 2008 | 05:49 PM
UfoTofU's Avatar
Default Re: (i_VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i_VTEC &raquo;</TD></TR><TR><TD CLASS="quote">I just did it and it works, But i broke one of the tabs that holds that plastic piece in. I swear you have to be hella careful when removing plastic parts from an EF because I don't think i have ever removed a plastic piece from my CRX where i didn't break something haha. </TD></TR></TABLE>
The plastic and clips do get really brittle.
You got pics of your before and after?
Old Jun 9, 2008 | 08:12 PM
gator88's Avatar
Default Re: (UfoTofU)
looks easy. too bad i use mine quite often. I might rainX the **** out of it and do this for a cleaner look though.
Old Jun 9, 2008 | 09:40 PM
acmoc's Avatar
Default Re: (gator88)
how do you remove the wiring all the way to the switch, and the washer thing and hoses
Old Jun 9, 2008 | 10:06 PM
SIred91's Avatar
Rainman
Default Re: (acmoc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gator88 &raquo;</TD></TR><TR><TD CLASS="quote">looks easy. too bad i use mine quite often. I might rainX the **** out of it and do this for a cleaner look though.</TD></TR></TABLE>
x2......I use mine quite often and like the "its an si" look too...
Old Jun 9, 2008 | 10:08 PM
SIred91's Avatar
Rainman
Default Re: (SIred91)
If I had the appropriate sized rubber grommet, I just might try it for looks....
Put up before and after pix or TTIW.....
Old Jun 10, 2008 | 04:58 AM
gator88's Avatar
Default Re: (SD_Lurker)
EDITED:
previous post above this was deleted
Modified by gator88 at 11:25 AM 6/12/2008
Old Jun 10, 2008 | 05:26 AM
thevtecnician's Avatar
Informative
I couldn't see driving in the rain without that wiper though. Visibility through that rear window is bad enough when its NOT raining! All the cars behind me look lowered lol!
Old Jun 10, 2008 | 10:13 AM
crxcess's Avatar
Default Re: (thevtecnician)
put RainX on the back glass, it works really well.
Old Jun 10, 2008 | 12:29 PM
SIred91's Avatar
Rainman
Hey Lurker......
Old Jun 10, 2008 | 12:58 PM
mainevnt's Avatar
hey i guys i did the same mod to my car(1989 Si hatch)
....but i had to leave a the hole open
any of you know the part number for the grommet??
thanks.
Old Jun 11, 2008 | 06:38 PM
mainevnt's Avatar
Default Re: (mainevnt)
any one???
Old Jun 11, 2008 | 08:05 PM
shocker's Avatar
go to hondaautomotiveparts.com they should have the grommet on there
Old Oct 20, 2008 | 04:11 AM
schroeder6th's Avatar
Default Re: CRX Rear Wiper Delete HOW-TO (STREETWERKZ)
Anyone removing a rear wiper motor, I'll take it for a reasonable price and shipping to 21771.
It must come "with all associated hardware" as we are fitting it to a different vehicle.
Thanks,
Fred
Old Oct 20, 2008 | 06:59 AM
harmonator84's Avatar
Default Re: CRX Rear Wiper Delete HOW-TO (schroeder6th)
Have been thinking about doing this for awhile.
wood 1
Mar 18, 2008 01:17 PM
egeeb16
10
Jun 28, 2007 01:40 PM
Mordeki
Apr 19, 2007 07:57 PM
VRD^don
Jul 27, 2006 06:46 PM
type Gendy
18
Dec 9, 2003 05:34 PM
