Bump stop questions
Old Apr 30, 2008 | 10:23 AM
PphamEK's Avatar
Default Bump stop questions
hi i have a 96 civic and just bought sum illuminas. when i got it my fronts did not come with any bump stops but my rear did. should i run the fronts wit no bump stop or should i just get sum for the fronts
Old Apr 30, 2008 | 02:47 PM
PphamEK's Avatar
Default Re: Bump stop questions (PphamEK)
bumP
Old Apr 30, 2008 | 04:15 PM
cherroneballs's Avatar
Hate to sound dumb but what are illuminas????
Old Apr 30, 2008 | 05:20 PM
pimpvw's Avatar
Default Re: (cherroneballs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cherroneballs &raquo;</TD></TR><TR><TD CLASS="quote">Hate to sound dumb but what are illuminas???? </TD></TR></TABLE>
struts
Old Apr 30, 2008 | 08:49 PM
AnotherSI's Avatar
Default Re: (pimpvw)
yeah you should use them, but when you take your old stuff off you reuse the old bumpstops. if your puttin on lowering springs make sure you cut them or they'll bottom out. there should be a chart to show ya how much to cut them.
Old Apr 30, 2008 | 08:55 PM
v!taminb16's Avatar
Default Re: (AnotherSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AnotherSI &raquo;</TD></TR><TR><TD CLASS="quote">yeah you should use them, but when you take your old stuff off you reuse the old bumpstops. if your puttin on lowering springs make sure you cut them or they'll bottom out. there should be a chart to show ya how much to cut them.</TD></TR></TABLE>
are you telling him to cut his spring's
Old Apr 30, 2008 | 10:09 PM
Neebs's Avatar
Use both bump stops. Some suggest to cut the bump stops in half to allow shock travel.
Old May 1, 2008 | 07:36 PM
AnotherSI's Avatar
Default Re: (v!taminb16)
no im not telling him to cut his springs! im sayin some manufactures of aftermarket suggest cutting the bump stops.
paradigm_shift
Dec 2, 2008 11:54 AM
iLOVEthatEMone
Jun 28, 2008 11:58 AM
cranberry
Mar 20, 2006 06:30 AM
cambopheonix56
Jul 29, 2005 10:51 AM
BOMBCRU
Jun 18, 2005 06:38 PM
