MY FIRST EF plz help me with my build
Old Apr 29, 2008 | 11:44 PM
DSRacing's Avatar
Default MY FIRST EF plz help me with my build
well here we go AGAIN! I part out my eg and BUILT ls-v cuz i was done with the scene and i just could not walk away so now.... starting all over. so i picked this car up from a buddy cheap he is off to iraq so lets BUILD IT UP.
I KNOW its ugly but i need to paint it ASAP!
when i picked up the car he told me he bought a new pump/filter/main fuse but car wont stay like running out of gas. so i drop the tank to see whats ^ and OF COURSE i get get the car running but its ruff i need more time to play with it.
complete interior with everything EVEN clean OEM cargo cover the interior is spotless
Old Apr 29, 2008 | 11:58 PM
DSRacing's Avatar
well lets start off with what is wrong then ill list what the car has and what i plan to do
ok well the car has a SOHC ZC(first single for me for the past 6 years been B) and first obd0 so i need to get use to it. ok well the car came with 2 ecu's inside both pr-4 and i plug one in i get code 13 and the other ecu gives me code 10 so im lost. he told me car wont stay on, the one with code 13 i got the car on i rev the gas and never seen so much black smoke in my life and i plug the other ecu with code 10 in and car runs maybe 5 secs then turns off. im thinking its the map?( to explain how lost i am with single cam i was tryin to get 1 of my old b-series maps to fit but no go)
PLZ SOMEONE any idea what i should check or do.
now what the car has for the price it was a great deal, car has a sohc zc,act clutch, momo wheel struts all around spot less interior he said ac works window washer everything works WOW for a 20 yr old ef im happy.
now me i am a huge fan of the oem look but built motor so this will not be much different. i work fast so i hope to make alot of progress asap.
in the morning i am sanding prep for paint i am 50/50 on the $50 paint job or paint with gun in my garage . but will prep either way later today. now i am going to try to get some hx's tonight.
i wanna swap the back seat to cloth(other then ef what other kinda back seat will fit nice and snug) after this i will start thinking about the motor i always been juice or motor THIS time i wanna try turbo so either sohc or b not sure will be thinking about this for a few days.
Old Apr 30, 2008 | 05:37 AM
Red_ED8's Avatar
Default Re: (DSRacing)
First off you need to get that running right. It's a SOHC ZC so its close to a D16A6 motor (came in the SI's and EX's) but someone please confirm this (not 100%). If it is, then I think you can run a PM6 ecu (again someone please confirm this). And I say if it's just a budged project, by all means do the rattle can paint job. Some people on here have done some nice looking $50 paint jobs.
Old Apr 30, 2008 | 10:43 AM
DSRacing's Avatar
yea thanx for the tip ill look in 2 that im going to the junk yard to stock up on a sensor or 2 and ill check for that ecu
Old Apr 30, 2008 | 11:41 AM
SIred91's Avatar
Rainman
Default Re: (Red_ED8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Red_ED8 &raquo;</TD></TR><TR><TD CLASS="quote">First off you need to get that running right. It's a SOHC ZC so its close to a D16A6 motor (came in the SI's and EX's) but someone please confirm this (not 100%). If it is, then I think you can run a PM6 ecu (again someone please confirm this). And I say if it's just a budged project, by all means do the rattle can paint job. Some people on here have done some nice looking $50 paint jobs.</TD></TR></TABLE>
Its the same motor as an A6. EXACTLY. minor diff on the cam, thats it.
Use a PM6.
A pr4 is dohc.....no wonder you are having issues.
Old Apr 30, 2008 | 12:08 PM
kowcain's Avatar
lol luv the camo paint .. i would keep the z6 in there and turbo the **** out of that..
Old Apr 30, 2008 | 01:52 PM
DSRacing's Avatar
just came back from the junk yard and could not get what i went for which was the map found and bunch but the map is hard to get out im use to it being up front on top not on the side i am very very strong but could not crack the screw loose so i just gave up i buy one from some where. BUT i did find the cleanest pm6 and some fuses and a plastic for the back light and a cleaner ash tray so i guess i did good and i been sanding like a mad man i want that camo off! people are telling me what happen your taking steps back you went from a clean oem eg that was a 11's all fay car to this SO I WILL make it my goal to make this car cleaner and faster!
Modified by DSRacing at 7:48 PM 4/30/2008
Old Apr 30, 2008 | 03:05 PM
senna 1's Avatar
Default Re: MY FIRST EF plz help me with my build (DSRacing)
cool paint job.
Don't see too many like that.
Old Apr 30, 2008 | 05:56 PM
DSRacing's Avatar
Default Re: MY FIRST EF plz help me with my build (senna 1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by senna 1 &raquo;</TD></TR><TR><TD CLASS="quote">cool paint job.
Don't see too many like that.</TD></TR></TABLE>
YEA? that does not get play over here in cali i start sanding and everyone is telling me good "we thought you were serious about is paint job" im glad to see it go so here is a update where i am at NOW
now i need to get the HX'S did not get a chance to go pick them up yet i think hx would look good on dis when its painted any one disagree? im going outside in a while to go try to get it run and stay one no black smoke no shutting off just in good shape, i hope he didnt kill the motor he had it advanced all the way and sum hope i can get it to run i changed over to the pm6 still same code but i cant turn the car on until i get a jump.
Modified by DSRacing at 7:57 PM 4/30/2008
Old Apr 30, 2008 | 06:03 PM
DSRacing's Avatar
i stop sanding because i wanna change the bumpers over to 91 front and back and i need the moldings for the door then ill paint it kinda buzz kill that i had to stop. QUESTION what the diff with 88-89 fenders and 90-91 because driver fender is snug pass there is a space from the corner light maybe 3/4 inch or so. QUESTION any one seen the back rims before know what they are?
Old Apr 30, 2008 | 06:25 PM
Clipsed's Avatar
DS are either of those PR4's OBD1? I have a PM6, you live in the 626 so do I, I will trade you for a PR4 if OBD1 since you have two, if not give it to you for cheap. LMK bro!
Old May 1, 2008 | 04:22 AM
newtyfruits's Avatar
i love the da seats.. lol looks like a fun build. keep pics updated..
Old May 1, 2008 | 12:39 PM
DSRacing's Avatar
WELL..... turned the car on it was running then i try to go around the block and then find out EITHER the short shifter is trash and off setting the gears or tranny is trash takes a lil work to find the gear it sounds like im tryin to put it into gear with out the clutch but when it finds the gear its all good
THEN t/b is getting stuck and when i first turn it on the car rev up fine then like 2 mins later got sluggish so i wanna play with that
so here is where i am @ i wanna take the short shifter off and im getting code 3 so when i change the map ill see if it all gets better.... it runs fine then smokes i dont know alot sohc but im working on it
DRatedA.W.D.
Dec 8, 2011 11:21 PM
FreddieC
10
Jan 14, 2011 05:02 PM
j3wman
20
Aug 17, 2009 10:47 AM
mrjingles8705
20
Jul 28, 2008 11:41 AM
boosted28
Appearance Build Threads
25
May 3, 2008 07:41 PM
