OIL LEAK near pan and oil pump
Old Apr 29, 2008 | 09:41 PM
Quickridez_3's Avatar
Default OIL LEAK near pan and oil pump
My b18c5 turbo motor is leaking tords the bottom of the block by the oil pan and oil pump. We thought that the problem was the o ring in the oil pump but we put new o ring on the pump and the crankshaft seal. We used good amounts of honda bond hoping for a strong seal.
The leak didnt go away
We tried replacing the oil pan gasket and used rtv black on both sides of the gasket
It appears to be fine there but the leak is still coming.
Here is the list of places that we checked
Breather on the back of the block
Oil feed line for turbo
Oil filter
ALL CHECKED OUT DRY no signs of oil
I know someone has had this problem before so please help me out.
Trying to take it out to the race track by this friday so im trying everything possible
THANKS
Old Apr 29, 2008 | 10:30 PM
jDMJeRk's Avatar
Sometimes the little round metal sleeves in the pan gasket are stuck to the bottom of the block, are you sure you throughly cleaned the block?
Quickridez_3
May 1, 2008 12:17 AM
Quickridez_3
Apr 30, 2008 09:44 AM
BILLY_BLING
Oct 16, 2006 03:05 PM
teler86
May 31, 2006 08:54 AM
