Suspension & Brakes Theory, alignment, spring rates....
Help Needed
Old Apr 29, 2008 | 07:33 PM
ImaHondaLover's Avatar
Default Help Needed
Ok, I was in the process of installing the Tein basics I just bought for my integra. I had the stock shock assembly out and was trying to loosen the nut that holds on the top hat using the alan wrench in the shock rod, so it doesnt spin, and a 14mm open end wrench taking off the nut. Anyway, doing this I somehow stripped the part of the shock where the alan wrench goes.
How can I get around this and get the tophat off when the rod is stripped? When I try to take the nut off now the rod just spins and since it is stripped in the end i can not stop it from spinning.
Old Apr 30, 2008 | 12:47 AM
ejprimo's Avatar
Default Re: Help Needed (ImaHondaLover)
use an impact gun, works for me everytime!
Old Apr 30, 2008 | 09:46 AM
PIC Performance's Avatar
Why are you trying to loosen that nut in the first place?
Old Apr 30, 2008 | 10:17 AM
Default Re: Help Needed (PIC Performance)
I am taking off the top hat. why else would i loosen the nut?
Old Apr 30, 2008 | 10:18 AM
Wouldn't the impact gun spin the shock rod?
Old Apr 30, 2008 | 02:19 PM
ejprimo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ImaHondaLover &raquo;</TD></TR><TR><TD CLASS="quote">Wouldn't the impact gun spin the shock rod?
trust me itll take the nut off, i do it all the time on my GC/koni combo..no problems so far
are you trying to remove stock springs on stock shocks?
Old Apr 30, 2008 | 03:19 PM
Default Re: Help Needed (ejprimo)
Yea I was taking off the stock tophat to put onto my tein basics because i didn't get the tophat. Anyway, I didn't have an impact gun so I had to cut off the nut then break it off with a drill and hammer and chisel haha. Worked like a charm. Thanks for the responses
BANNED_ID
25
Sep 24, 2006 03:04 PM
bizzlekip
Suspension & Brakes
Jan 31, 2006 09:48 AM
AJxr
13
Oct 7, 2005 05:54 PM
eMpAtHy
Suspension & Brakes
Jun 26, 2005 07:31 PM
pearl
Sep 22, 2004 02:10 PM
