Suspension & Brakes Theory, alignment, spring rates....
want to add sway bar to civic...what parts do i need???
Old Apr 29, 2008 | 07:11 PM
95 civic turbo_gsr's Avatar
Default want to add sway bar to civic...what parts do i need???
i have a 95 civic dx and i want to install a rear sway bar. can i just use some parts off a similar year integra? is so, what model? will i only need the lca's? if i put on lca's from an integra can i install any aftermarket sway bar i want? need help...thanks...
Old Apr 30, 2008 | 12:48 AM
BlueIntegraBoy's Avatar
Default Re: want to add sway bar to civic...what parts do i need??? (95 civic turbo_gsr)
94-01 Integra. If you put on an ITR bar, you will need subframe reinforcement. You need LCAs, sway bar, endlinks, brackets, bushings, and bolts.
Old Apr 30, 2008 | 09:50 AM
Default Re: want to add sway bar to civic...what parts do i need??? (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">94-01 Integra. If you put on an ITR bar, you will need subframe reinforcement. You need LCAs, sway bar, endlinks, brackets, bushings, and bolts.</TD></TR></TABLE> do the gsr and ls models have the setup? I would like to use an aftermarket sway bar.
Old May 1, 2008 | 08:57 AM
need more info
Old May 2, 2008 | 06:40 PM
are there any websites i that sell used suspension parts?
mish__
Suspension & Brakes
Aug 8, 2011 10:02 AM
B_quinhas
Suspension & Brakes
10
Aug 11, 2009 06:19 PM
eg6sir88
Suspension & Brakes
Aug 10, 2007 07:02 AM
Wolfwood
Suspension & Brakes
Aug 26, 2005 11:06 AM
nxstrikerxn
Suspension & Brakes
Apr 2, 2005 09:57 PM
