TPS???
Old Apr 29, 2008 | 06:38 PM
driftam1's Avatar
Default TPS???
ON the tps there r 3 wires a red green and yellow so do you jus switch the yellow and green?
Old Apr 30, 2008 | 12:08 PM
Mr.Death's Avatar
Your question make no sense at all. Think, type, prevail!
Old Apr 30, 2008 | 12:11 PM
kowcain's Avatar
he wants to know witch wires to swap on the tps to do a mpfi swap.. use search **** look at some of the other posts on here and then you will see the dpfi- mpfi topic right under this one somewhere we have like 3 urls you can go too and see witch ones to swap.. and if that isnt enough you can always go to google :D
but because im a nice guy i'll help you
On the TPS plug on the DX harness you will see 3 wires going to it, yellow, red, and green, in that order (if you are looking at the top of the clip from left to right on the DX clip). Depin and switch the green and yellow wires around so now the order is green, red, yellow.
mr. Grind
Mar 12, 2014 02:58 AM
89civicdxx
Mar 29, 2005 03:56 PM
thatbluecrx
Feb 17, 2005 09:58 AM
jhmcrx
Dec 25, 2004 05:28 PM
bemathew
Oct 28, 2001 01:40 AM
