JDM climate control in USDM rex?
Old Jul 12, 2002 | 10:29 PM
hahagasdcrx's Avatar
Default JDM climate control in USDM rex?
does anyone know how to do this or if it can be done. i have every part for the job but wonder if it is worth the effort... i know i have every part cause i have a whole jdm front clip but dont wanna hack up this crx to make RHD will do to another one sometime down the road..... please post if you know or email me at
hahagasdcrx@aol.com
Old Jul 12, 2002 | 10:33 PM
slowman's Avatar
I took way too long
Default Re: JDM climate control in USDM rex? (90crxzcgasd)
just curious, whats the difference between the JDM vs USDM?
Old Jul 12, 2002 | 10:34 PM
bryant's Avatar
I have seen ppl that have it, But as far as it working and how they did it, im not sure
JDM has climate control. Just set your Temp and it does all the work.
[Modified by CR-X, 1:35 AM 7/13/2002]
Old Jul 13, 2002 | 08:51 AM
VTECVillain's Avatar
Default Re: JDM climate control in USDM rex? (CR-X)
From what I understand the JDM climate controls are completely electronic with no cables. I'm sure if you ask around enough you could find some hardcore JDM'ers that have fully-functional ones in the car.
Old Jul 13, 2002 | 09:37 AM
93eg-EKhybrid's Avatar
Default Re: JDM climate control in USDM rex? (VTECVillain)
Where did you get the full front clip from? Let me know cause I am looking for one.
Old Jul 13, 2002 | 01:05 PM
Default Re: JDM climate control in USDM rex? (h22ybridAccord)
i got the front clip from j spec a while back
Old Dec 13, 2002 | 01:01 AM
Jsmx5's Avatar
Anyone ever figure out how to do this swap?
Im thinking about doing it as well so any help is appreciated.
Thanks,
Old Dec 13, 2002 | 01:50 AM
Fobtions's Avatar
Default Re: JDM climate control in USDM rex? (Jsmx5)
i have the climate control. everything works but the cold/hot settings. i have it "riggged" so i can adjust temp under the dash using pieces from the usdm one.
Old Dec 13, 2002 | 05:13 AM
l0p3z's Avatar
Default Re: JDM climate control in USDM rex? (slowmanEF)
according to jdmpartz.com, the unit will fit perfectly but is not a plug-n-play deal. assuming you might have to run a few wires.
Old Dec 14, 2002 | 06:37 PM
Jsmx5's Avatar
Default Re: JDM climate control in USDM rex? (Fobtions)
Do you have a crx or hb?
I think i read somewhere that the crx wiring/controls are different than the hb?
Do you have any wiring diagrams ?
I saw the back of the jdm climate control.... it has a ton of wires.
i'd really like to get it fully operational.
As always.. all help is greatly appreciated.
Old Dec 15, 2002 | 04:20 AM
Fobtions's Avatar
crx was plug and play except for the actual temp settings, and i dont know about the a/c switch
Old Dec 15, 2002 | 05:33 PM
Jsmx5's Avatar
Thanks Fobtions...
Anyone else have any input?
Thanks,
EViLSTAR
Mid-Atlantic (Sales)
May 4, 2010 03:46 AM
High Octane
Jul 30, 2009 12:24 PM
crdcz03
Mar 23, 2005 07:30 PM
AllMotorITR
Jun 3, 2003 10:07 AM
