Water leaking onto floorboard
whenever i take turns, water drips down onto my or my passenger's feet from somewhere above the front floorboard. This happened to my integra a few years ago and i took it to a shop and they said it was common and it was an easy fix but i can't remember what they did (the fixed it for free). i think they basically said something gets clogged and causes the water from the air conditioner to drain inside the car instead of outside it. does anyone know what this is and if i can fix it myself quickly.
thanks
thanks
there is a tube that allows water to drain from your evaporator, that more than likely, is clogged.
unless you want to take your whole dashboard apart to remove whatever clog there is, you can (more than likely this is what the shop did as well) get some compressed air and shoot it through the bottom of the hose that the water is supposed to drain from, this should unlodge anything that is clogging the drain.
dlenoxx
Dec 2, 2010 12:05 PM
PatrickGSR94
Jan 13, 2005 12:21 AM
