600 whp, what trans?
Old Apr 29, 2008 | 10:08 AM
slammedobd1teg's Avatar
Default 600 whp, what trans?
my boy opted to put his type r trans in his daily, because it was begining to grind at high rpms and we figured we would try and save it, so now he needs to buy a new trans for his strip / street car.
more strip then street. should be making 600-650+
2.0 lsvtec, 35r, 24.5 slicks.
what trans or even what gear combo would yeild the fastest 1/4 times?
Old Apr 29, 2008 | 10:25 AM
BLKTeg94's Avatar
Liberty trans, GSR gear ratio's
Old Apr 29, 2008 | 10:44 PM
IT'S ME DAVID's Avatar
NooB
Default Re: (BLKTeg94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLKTeg94 &raquo;</TD></TR><TR><TD CLASS="quote">Liberty trans, GSR gear ratio's</TD></TR></TABLE>baller
Old Apr 30, 2008 | 04:53 AM
taggart_lumpy's Avatar
gsr
quaife
racer stev gears
Old Apr 30, 2008 | 04:57 AM
Blown90hatcH's Avatar
Default Re: 600 whp, what trans? (slammedobd1teg)
b16/itr is going to accelerate the quickest, but if you don't have a good suspension setup, boost controller that can do boost by gear, etc.....you will be spinning. Do the gear calculator and see what you need....mph, wheel size, etc.
Or go stereotypically and get the LS to stay in boost longaR.
Old Apr 30, 2008 | 05:41 AM
Will_H's Avatar
im kinda in the same boat as the OP im around the 650hp range running on a LS tranny with a Quaife, 3rd gear is starting to grind, trying ot decide whats the best trans or setup to go with, Racerstev treated gears and not sure about the rest
Old Apr 30, 2008 | 08:18 AM
Default Re: 600 whp, what trans? (Blown90hatcH)
car is on k sport drag suspension, and s300 for boost by gear
really trying to get an idea of what trans to go with, and possibly swap out some gears.
Old Apr 30, 2008 | 09:06 AM
nobody else has any input?
Old Apr 30, 2008 | 09:18 AM
slotec's Avatar
also wondering. Im using a b16/itr tranny
Old Apr 30, 2008 | 09:27 AM
locash's Avatar
Default Re: 600 whp, what trans? (slotec)
For the 600+ mark, it would be a wise investment to buy an aftermarket gearset if you can get one. Either that, or learn how to fix the stock one yourself, because you're going to need to replace parts often.
Old Apr 30, 2008 | 09:46 AM
Default Re: 600 whp, what trans? (locash)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by locash &raquo;</TD></TR><TR><TD CLASS="quote">For the 600+ mark, it would be a wise investment to buy an aftermarket gearset if you can get one. Either that, or learn how to fix the stock one yourself, because you're going to need to replace parts often.</TD></TR></TABLE>
who makes a good gearset?
Old Apr 30, 2008 | 09:53 AM
joe111599's Avatar
Ive always loved the gsr trans. Gearing is almost perfect for me.
Old Apr 30, 2008 | 09:56 AM
Default Re: (joe111599)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joe111599 &raquo;</TD></TR><TR><TD CLASS="quote">Ive always loved the gsr trans. Gearing is almost perfect for me. </TD></TR></TABLE>
im beginning to think a gsr with a quaife is the way to go.
Old Apr 30, 2008 | 09:58 AM
VisualAutoMotoring's Avatar
Default Re: (slammedobd1teg)
Liberty, PPG, G-force all make great gearsets and have all been proven
Tons of people like Joe Simpson, Courtney Green, Stephanie Eggum and am I sure other s run the Liberty.
I believe Felix Medina runs the G-Force set
Old Apr 30, 2008 | 12:37 PM
2 0 3's Avatar
Default Re: (Hybrid-Performance.com)
If you cant afford an aftermarket trans. (i know i can't) I would just stick with OEM gsr gears, treated or not. That's up to you, I personally think the treatment helped us. But some others beg to differ. But for that power level and what the car should trap, i think the b16 would be to short. Unless your reving it out past 10k. Im putting a new trans together tomorrow, I will be using a cuff in place of 5th gear.
I'll let you know how that goes.
Remember you can also mix ratio's. All hydro B's use the same setup, don't be afraid to try something new. some b16 some gsr. See what it does for you.
Old Apr 30, 2008 | 02:40 PM
Default Re: (rota92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2 0 3 &raquo;</TD></TR><TR><TD CLASS="quote">If you cant afford an aftermarket trans. (i know i can't) I would just stick with OEM gsr gears, treated or not. That's up to you, I personally think the treatment helped us. But some others beg to differ. But for that power level and what the car should trap, i think the b16 would be to short. Unless your reving it out past 10k. Im putting a new trans together tomorrow, I will be using a cuff in place of 5th gear.
Remember you can also mix ratio's. All hydro B's use the same setup, don't be afraid to try something new. some b16 some gsr. See what it does for you.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rota92 &raquo;</TD></TR><TR><TD CLASS="quote">I put ~35 hard launches on a stock GSR gearset with quaife last season at 600 without a problem. IMO it's luck of the draw lol
The trans was 100% overhauled though, it was a joy to shift.</TD></TR></TABLE>
thanks guys, those were exactly the anwseres i was looking for!
im thinkin gsr 1st and 2nd, b16 3rd and gsr or ls 4th, ls 5th (for highway cruising)
any more input i would be happy to listen to!
Old Apr 30, 2008 | 04:51 PM
Default Re: (2 0 3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2 0 3 &raquo;</TD></TR><TR><TD CLASS="quote">But for that power level and what the car should trap, i think the b16 would be to short. Unless your reving it out past 10k. </TD></TR></TABLE>
My car went 149mph at 9800rpm. Making somewhere around 650 or so...2600lbs with me in it...ITR tranny. Racerstev treated my gears a while ago too....30+ 10.1-10.2 passes and thousands street miles beating on it everywhere I go.
The GSR tranny is a good all around ratio setup though and many people opt for it.
OP, the GSR and ITR 1st are the same gears and since you have the ITR tranny...use them. ITR 1-4, LS 5th or ITR 1-3, GSR 4ths and LS 5th. That is what I just switched to as I am out of mph with the ITR gears and moving up in power.
Old May 1, 2008 | 06:36 AM
Default Re: (Blown90hatcH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blown90hatcH &raquo;</TD></TR><TR><TD CLASS="quote">
OP, the GSR and ITR 1st are the same gears and since you have the ITR tranny...use them. ITR 1-4, LS 5th or ITR 1-3, GSR 4ths and LS 5th. That is what I just switched to as I am out of mph with the ITR gears and moving up in power. </TD></TR></TABLE>
the itr tranny was put into his daily, i think the setup is gunna be gsr 1-4 ls 5th quaife lsd
still gotta be able to cruise to the beach and get the babes
AFAccord
Transmission & Drivetrain
Feb 8, 2016 10:21 AM
b00stedbyFastrax
Oct 5, 2008 03:15 PM
4piston
Oct 20, 2005 02:27 PM
hybridpatient95
14
Apr 7, 2005 04:47 AM
