ngr short hub
Old Apr 29, 2008 | 08:13 AM
s2khic's Avatar
Default ngr short hub
anyone running the nrg short hub ? if so how good is it ? thinking about picking up a nrg short hub with the thin version quick release kit.... anyone ?
Modified by s2khic at 6:00 PM 4/29/2008
Old Apr 29, 2008 | 01:56 PM
acmoc's Avatar
Default Re: ngr short hub (s2khic)
Same here
Old Apr 29, 2008 | 03:22 PM
DCFerris's Avatar
i have the nrg short hub and 2.0 quick release. It works good i dont have power steering and its easier to turn from a stop. its a good investment get it. if you have anymore ?'s let me know.
if you looking at getting it, http://www.racinglab.com/steer....html
i think has the best prices if that not where you were looking.
Old Apr 29, 2008 | 05:44 PM
acmoc's Avatar
Default Re: (DCFerris)
reason I ask is because I found this on weaksauce, Nrg short hub for a 88-91 ef
*Buy at your own risk
-We asked the NRG innovations technician regarding this short hub for the 88-91 Civics and they said it would fit with modifications. Here are the modifications needed:
1. Horn might not work
2. This piece will rub against the steering collumn. You must file/dremmel the plastic around the turn signal cancellation piece.
3. None of the accessories will work (cruise control)
4. The turn signal cancellation might not work. (Need to manually flick turn signal off)
http://www.weaksauceparts.com/...age=1
Old Apr 29, 2008 | 09:04 PM
DCFerris's Avatar
yeah you do have to modify the horn to work this will show how
http://www.getnrg.com/support/...ID=14
its not for an ef but i did this to my crx
and yeah you have to file the clicker down if you really really want to keep it but i just took it out its not that big of a deal for me but if you really want to keep it then your just gonna have to take the time to file it down until you have enough room for the hub to slide all the way down. and for the cruise control i didn't have it i dont think any ef's have cruise control but i could be wrong
Modified by DCFerris at 10:16 PM 4/29/2008
Old Apr 30, 2008 | 11:01 AM
s2khic's Avatar
wow sounds like a lot of drama..... so if you go with the short hub is it better to go with the 2.5 quick release or the thin quick release kit ?
Old Apr 30, 2008 | 12:07 PM
GSR CRX's Avatar
Default Re: (s2khic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s2khic &raquo;</TD></TR><TR><TD CLASS="quote">wow sounds like a lot of drama..... so if you go with the short hub is it better to go with the 2.5 quick release or the thin quick release kit ? </TD></TR></TABLE>
i think the 2.5 just has the butterfly quick release. that is all that is different. i would just stick to the 2.0. i also had the problem of turn signal clicker so i just took it out. as for the horn it should work fine since it has the metal contact strip unlike anything with an air bag which dont have that contact point. and as far as cruise control goes it only came on the lx and ex sedans i believe. not a lot of drama just gotta get it and do it. for this product.
Old Apr 30, 2008 | 02:03 PM
rich_one1's Avatar
if you run the short hub and thin version quick release I heard it won't work since it will be too low and too close to the turn signal flickers.
Old Apr 30, 2008 | 02:31 PM
s2khic's Avatar
Default Re: ngr short hub (rich_one1)
thanks for all the help guys ..... I really like the butterfly 2.5 but if the 2.0 works better i guess thats what i should go with. any of you guys know which one is shorter - the 2.0 or the 2.5
thanks again guys !
Modified by s2khic at 11:45 PM 4/30/2008
Old Apr 30, 2008 | 03:27 PM
acmoc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s2khic &raquo;</TD></TR><TR><TD CLASS="quote">thanks for all the help guys ..... I really like the butterfly 2.5 but if the 2.0 works better i guess thats what i should go with. any of you guys know which one is shorter - the 2.0 or the 2.5
thanks again guys !
Modified by s2khic at 11:45 PM 4/30/2008</TD></TR></TABLE>
I was thinking bout maybe, a regular hub and a thin quick release.
What about that works bell company. no ones using those
Old May 1, 2008 | 08:25 AM
s2khic's Avatar
Default Re: ngr short hub (acmoc)
i think its cause the works bell is SOOOOOOOOO EXPENSIVE hahaha
sbk23
Dec 25, 2009 12:25 AM
kidari
Oct 19, 2009 01:56 AM
crxmadman
Jul 11, 2005 12:36 PM
monicle
Mar 8, 2005 04:19 AM
