temperature???
Old Apr 29, 2008 | 07:36 AM
dylokjai's Avatar
Default temperature???
i was driving to work 40miles during the afternoon nice sunny hot day the temp gauge stayed at 1/4 then after work 215AM while driving i notice my guage go past that so i pull over in the freeway pop the hood and notice no coolant leak so i continue on driving now the temp is at 1/4 when i apply gas it stays at 1/4 when i step on it it goes up a lil bit when i slow down its rises my fan stays on all the time previous owner wired it to stay on when the ENGINE IS ON. Can oil play a role in this temp issue i was a lil low on oil? theres no gunkny milky in the motor or iin the rad
Old Apr 29, 2008 | 01:59 PM
acmoc's Avatar
Default Re: temperature??? (dylokjai)
bump
Old Apr 29, 2008 | 02:34 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: temperature??? (acmoc)
The "problem" is that an EF radiator is nearly too big for the engine, so on the highway, you dont even need a radiator fan. oil might play a role, but unless your engine goes above the half mark on the temp guage, i would not worry about it.
as a side note, i drove for about 8 months without a radiator fan at all, not knowing it was unplugged for some reason when i bought my car. It was only sitting in an abnormally long drivethrough line on a 100 degree day did my car give any symptom that something was wrong. even still, my radiator fan rarely comes on unless i am driving it hard or sitting at a stoplight on a hot day.
Old May 1, 2008 | 10:26 PM
dylokjai's Avatar
Default Re: temperature??? (sanimalp)
yes i should worry about it.....it was my water pump leaking water from the weep hole.
Old May 2, 2008 | 07:20 AM
sanimalp's Avatar
$cat /dev/urandom
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dylokjai &raquo;</TD></TR><TR><TD CLASS="quote">yes i should worry about it.....it was my water pump leaking water from the weep hole.</TD></TR></TABLE>
in your original post, you said it wasn't leaking.. now it is, so you *should* worry about it. I stand by what i said earlier, given the information you provided originally. That information changed, and so does the diagnostic.
Old May 8, 2008 | 08:04 AM
dylokjai's Avatar
got same problem still but no leak. my lower rad hose is always cold is that normal?
Old May 8, 2008 | 08:07 AM
EFstyle's Avatar
Default Re: (dylokjai)
well that meens the thermostat isnt opening... so the lower hose is cold no matter how long and far you drive it?
Old May 8, 2008 | 09:22 AM
dylokjai's Avatar
Default Re: (EFstyle)
i drive it for an hour in the freeway its still cold and the top hose is hot
Old May 8, 2008 | 11:47 AM
EFstyle's Avatar
stuck thermostat
Old May 8, 2008 | 01:31 PM
sanimalp's Avatar
$cat /dev/urandom
pull out the thermostat and drive it again. if it still does it.. then I have a solution. if it doesn't, then you know what the problem is.
KillinEm18
Dec 4, 2012 03:07 PM
llltrunkslll
14
Jan 13, 2010 08:16 AM
loup05
Dec 11, 2008 04:43 PM
spock_rocker
Jun 6, 2005 03:32 PM
miksew
Jan 3, 2004 08:10 PM
