rear subframe replacement
i wrecked my integra and it needs a rear subframe.
are there any differences between avalible integra subframes? are civic subframes interchangeable with the integra subframe?
i bashed a curb really hard in the rain and twisted up the lca mounting point pretty bad.
I'm assuming '94-01 Integra?
All '92-95 Civics and '94-01 Integras use the same rear subframe regardless of trim level or number of doors, with the exception of the ITR.
ITR vs. non-ITR subframes are different but interchangeable; the ITR has reinforced sway bar mounting points to avoid tear-out when using larger rear sway bars (22-23mm) without an aftermarket reinforcement kit. That's the only difference that I am aware of.
i had acura dig up all the part numbers and just ordered a type r subframe, it was $2 more than a normal integra/civic one.
i was going to pull one off a junk car, but it was only 170 shipped next day
creechrr
Jan 18, 2003 04:46 PM
