ITR Tranny and it's bolts. HELP!!
Hello my fellow ITR-ians or ITR-tians whatever, anyways i need help and i need it fast. My question is what bolts can i substitute for the studs in the top mount on the transmission (passenger side mount)?? Since all 3 threaded holes are the same size, i know the two of the three holes take studs but i dont have time to order studs. But i have a honda dealership connect and i can rumage thru their bolts.
Would it be bolt #46 in this pic? check it out:
http://www.acuraoemparts.com/d...ch=no
Any help or input would be greatly appreciated. TIA
yes bolt 46 is the bolt used on the top tranny mount. the other two are nuts that go on studs that come off the trans.
contact innovative mounts. they provide a different bolt with their mount kits instead of #46 in the diagram. maybe they will tell you what the thread size is or help you out so you can hit up a local hardware store.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2R »</TD></TR><TR><TD CLASS="quote">yes bolt 46 is the bolt used on the top tranny mount. the other two are nuts that go on studs that come off the trans.
contact innovative mounts. they provide a different bolt with their mount kits instead of #46 in the diagram. maybe they will tell you what the thread size is or help you out so you can hit up a local hardware store. </TD></TR></TABLE>
Yeah i should call them, that's a good idea. I never would of thought
Also, bolt #46 should thread into the holes that the studs normally go into, right??
azhfreak
Aug 27, 2018 11:21 AM
Linked
12
Mar 2, 2010 10:55 AM
webbs2jzgte
Jan 12, 2010 06:04 PM
