Are these the same as Koni Yellows?
Old Jul 12, 2002 | 08:16 PM
spdster's Avatar
New User
Default Are these the same as Koni Yellows?
Sorry for the noob post,
I went to my local performance shop dealer and asked for a set of koni yellows and this is what he brings out.
Koni "Neuspeed Edition" Sport Shocks
Here's the blurb off the dealer pamphlet that he gave me.
"This series are designed to provide a more aggressive upgrade when compared with the factory setup. It will have a considerable valve rate increase in compression and rebound to provide the highest level of handling possible. Certain vehicle applications will also feature a special height adjustment feature that allows the user to give additional height increase or height reduction desired. The "Neuspeed Edition" Koni shocks feature an improved design over the traditional Koni Sport models. It includes a shorter piston assembly as well as 5 adjustable spring perches instead of 3 on height-adjustable models."
Old Jul 12, 2002 | 09:58 PM
frogsr's Avatar
Default Re: Are these the same as Koni Yellows? (spdster)
your answer is basically in that pamphlet quote you just posted. they are koni yellows, but modified/revalved to neuspeed specs to work with their specific springs/springrates. koni's are very good.
Old Jul 12, 2002 | 10:00 PM
spdster's Avatar
New User
Default Re: Are these the same as Koni Yellows? (frogsr)
awesome thanks man...heading down tomorrow to pickup a set.
bigmike321321
Suspension & Brakes
Jun 22, 2008 04:10 PM
the soL that could
Suspension & Brakes
Feb 6, 2006 06:27 PM
baonest
Aug 4, 2002 12:16 AM
spdster
Jul 14, 2002 10:51 AM
taytay333
Mar 26, 2002 03:54 PM
