H22 auto trans in crx?
r u asking if just the trans will work? or the whole h22 swap? if just the trans, then definate no. im sure the whole swap could, but a manual swap, even using a b16, would be cheaper i would imagine. gl
Yes it's possible, id imagine it's cable operated with the auto h22, you just need to make your own custom transmission mount. We have sold our kits to a couple EF H22A Auto guys we supplied them the material to make the custom auto tranny mount.
Rear mount and driver mount should be the same as a 5 spd EF H22 swap
To the OP:
Since H22 5-speed uses a big shifter pot that bolts down to the floor anyway, it's not that hard to install. The pedals would be more work than anything probably, as far as Auto-to-Standard goes. Good luck!
