First CRX.. a couple questions
Old Apr 28, 2008 | 07:00 PM
DarkSideofOZ's Avatar
Default First CRX.. a couple questions
First off here it is...
and
As you can see it's bone stock, even with the factory rims.
I want to change these out imediately, but I need to know the limits. I want 14"/15" but I dunno the "sizes" to look for, or what would look best. Keep in mind i will be getting the car painted black soon.
Old Apr 28, 2008 | 07:18 PM
spikehead221's Avatar
From: Staring down the barrell of my 12 ga. Texas, USA
Default Re: First CRX.. a couple questions (DarkSideofOZ)
search
look at the pic thread
etc.
15 will fit at stock height without modification (I believe)
p.s. where in arlington, i go to uta
Old Apr 28, 2008 | 07:40 PM
I looked through the FAQ, but didn't see anything on ri measurements.
I also looked through the pics thread and I'm pondering on some 15" 5 spoke white or metalic gunmetal rims, but as for the other measurements, I haven't a clue what to look/ask for. I don't wanna order online till i know I'm getting what I need.
p.s. I'm in south arlington down off 20 near 287.
Old Apr 28, 2008 | 07:47 PM
zrickety's Avatar
205/50R15 fit perfectly...speedometer is right on
Old Apr 28, 2008 | 07:54 PM
the fat fives are 15 and dont have clearance issues that i can find
they look like this, the tires on are 195/55/15
http://www.hondamarketplace.co...78927
if you are lookin to drop the car, as long as u do it right, u should still be able to run 15's easy.
also, if you want after market, any store should test fit possible wheels and tires.
Old Apr 28, 2008 | 08:13 PM
tree fingers's Avatar
Default Re: First CRX.. a couple questions (spikehead221)
15x6/6.5 wheels with 195/50/15 tires
38-45mm offset
Old Apr 28, 2008 | 08:26 PM
gursh d's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wheel and Tire FAQ &raquo;</TD></TR><TR><TD CLASS="quote">What size tires should I get?
The proper size depends on your car, not just the wheels you are using. So if you want to ask what size you should get, let us know what kind of car you have (year, model, body style, version)!
For a CRX, del sol, or pre-'96 Civic, the following sizes are usually best:
13" - 175/70-13
14" - 185/60-14, 195/55-14
15" - 195/50-15
16" - 205/40-16, 195/45-16
https://honda-tech.com/zerothread/1188922
You always can go bigger/wider, but then clearance becomes an issue. Post in the wheel/tire forum, the mod's there are extremely helpful.
I have 205/50/15 tires wrapped around a 15x7 wheel and it works great.
Old Apr 28, 2008 | 11:38 PM
DCFerris's Avatar
i have 15" rota slips on mine with 205/50r15 you can also go 195/55r15 i think black on black is clean
rexx5970
Jan 20, 2011 09:30 AM
pyro_freak8
Feb 28, 2004 03:24 PM
GroundZer0
Mar 6, 2003 06:34 PM
Comtechgsr2000s
Dec 13, 2001 06:42 PM
