camshaft help
Old Apr 28, 2008 | 06:24 PM
gsxt5r1's Avatar
Default camshaft help
so for the last 3 days i have been working on building my head. i have a gsr head and i bought stage 2 cams, valves, springs, retainers. i took the whole thing apart spent half a day cleaning the head i took out all the valves and springs one side at a time. i bought grinding compound and seated all the valves put on new seals and put the head back together. after putting in the new head gasket i set the head back on the block and fastened it to spec i set the cams by the book used lube torque wrench and gasket sealer in the needed spots. i changed the oil new anti freeze hooked all hoses vacuum lines and sensors back up. i set the timing at TDC with the gears and marks on the crank. i turned the crank at least 6 times by hand. put the wires in the proper order. i turn the key and the car cranks over but doesnt start and theres also a knocking noise coming from the motor what could i have done wrong? any help would be much appreciated
thanks,
dom
LDE
Honda Civic (2001 - 2005)
Oct 25, 2018 02:34 PM
EG6_978
Dec 21, 2008 08:28 PM
eg8d15b7
Jun 1, 2008 08:06 AM
