DC2 suspension on an EM1
I've found an Apexi N1 damper system for an Integra Type-R that is available to me on a trade, but i'm not sure if it will work on an EM1.
The system is Currently on an EJ using ITR lower control arms and I'm trying to find out what I would need to make this set-up fit on your typical EM1 or if it will at all.
Thanks in advance for your help,
Derek
Derek
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MR.ADAMS »</TD></TR><TR><TD CLASS="quote">Nobody knows how to run ITR shocks and springs on an EM1? Baffling...</TD></TR></TABLE>
The only way to run rear dampers with a lower eye-mount on a '96-00 Civic is to pay $300 for the special Function7 lower control arms that allow you to do so, as seen here. Otherwise, if they are full threaded body dampers with a detachable threaded lower mount, contact Apexi (good luck with that) and find out if you can purchase fork-type mounts for a '96-00 Civic.
It's all rather pointless if you ask me. I'd sell them and use the equity to buy something worthwhile that fits.
awdriscol4
Suspension & Brakes
21
Mar 11, 2005 10:34 AM
