Test Pipe in CSP?
Whenever you say exhaust must terminate behind driver, what are you saying? And what is the noise restrictions? I believe street legality is 100 db at 95 ft. Not 100% sure about that though.
Noise restrictions are dictated by the site where you are running. Some sites, due to residential areas around the site have greater noise restrictions. Just check with your local area.
As for behond the driver, the exhaust must exit the car at a location that is behind where the driver sits. They will allow you to have the exhaust exit directly in front of the rear wheel, but it must be on the passenger side of the car. Other wise it needs to be routed to the rear of the car. So basically, you can not run open headers.
Skunk2 Steve
Mar 16, 2003 11:08 PM
