obd2 emissions
Old Apr 28, 2008 | 10:15 AM
turbogsr18's Avatar
Default obd2 emissions
Okay i have an 1996 EK with a H22a1 (obd1) motor, but i have obd2 wiring with an obd2 to 1 conversion harness. If i take off the conversion harness and put obd2 ECU on there will i pass be able to pass emissions.
Keep in mind I will just have to pass the scanner where they plug into check for codes. I guess my main question is would it throw any codes if i put the obd2 ecu on it.
Old Apr 28, 2008 | 10:21 AM
Davus's Avatar
Default Re: obd2 emissions (turbogsr18)
Ahh just watch out for your distributor, OBD1 and OBD2 are typically not interchangeable, and thus you may have to swap that out as well.
And, of course, be sure to drive around with the OBD2 ECU to set all various factors.
(Also, get it done early, just in case there are problems/codes you need to sort out with OBD2.)
Old Apr 28, 2008 | 10:24 AM
turbogsr18's Avatar
Default Re: obd2 emissions (Davus)
oh yeah its got an obd2 dizzy to
Old Apr 28, 2008 | 10:37 AM
turbogsr18's Avatar
bumppppp?
EgSalad
Jan 30, 2007 07:57 AM
strictly.business
Nov 5, 2006 06:45 PM
beedoublejay
Aug 6, 2003 01:02 PM
ef ect
Dec 23, 2002 08:53 PM
