95 civic hand brakes help
car: 1995 civic vx w/ rear disc conversion
my hand brakes never really held tight...but now i guess its at the point where its becoming useless.
i parked on a hill and pulled my hand brakes up and the car kept rolling still.
my question is...
how do i fix this?
is there specific pads for hand brakes?
or is the rear disc pads the same one used when hand brakes is applied?
Modified by Sic_DA_Nine at 5:12 PM 4/29/2008
my question is...
how do i fix this?
Yea the same pads that are used when the pedal is pressed is the same pads that are used when you pull the emergency brake.Maybe your not pulling the e-brake far enough,maybe the pads are worn down or maybe you need to adjust the tension nut for the e-brake?
born2lose
11
Jun 17, 2012 06:27 PM
