Motorcycles Motorcycles and motorcycle parts for sale
2005 Yamaha YZ250f "SELL or TRADE" So. Cal (San Diego)
Old Apr 28, 2008 | 07:02 AM
H22a1civic's Avatar
Default 2005 Yamaha YZ250f "SELL or TRADE" So. Cal (San Diego)
2005 Yamaha YZ250 4 stroke $3500obo or trade for a Civic, Integra, or a street bike
Reg. Sticker through 2009, this YZ250F is in great running condition with a FMF Fatty V4 pipe, Excel rims, Hot start trigger & New rear sprocket.
Low hours and well maintained, I have decided to sell the bike due to lack of use!
For 2005, chassis and engine refinement continue to leave the competition farther behind.
The all-new 48mm fork finds its way onto the front of YZ250F's sharp-handling frame, and the trick new shock out back controls a more rigidly mounted, lighter swingarm. The result is better feel and feedback, consistent damping, and more comfort, all of which makes those long motos feel shorter.
More power unravels laps quicker too, especially since the redesigned engine delivers it super smooth from the instant you open the throttle.
* New intake ports
* New combustion chamber
* New piston
* Revised ignition mapping
... have all been engineered to produce smoother power and more of it, followed by a linear transition into the YZ250F's 13,500-rpm top end.
Add YZ handling and you've got the winner of the 2004 model, 250 four-stroke shootouts in Dirt Bike, Motocross Action and Cycle News. This year, the horses are even more ready, willing and able.
GENERAL INFORMATION
MANUFACTURER Yamaha
MODEL YEAR 2005
MODEL YZ250F
M.S.R.P. * $5,699.00
ENGINE
ENGINE Liquid-cooled, 5-valve, DOHC, 4-stroke w/titanium valves
DISPLACEMENT 249 cc
BORE X STROKE 77 x 53.6 mm
COMPRESSION RATIO 12.5:1
CARBURETION 37mm Keihin FCR flat-slide with throttle position sensor
IGNITION Digital CDI
DIMENSIONS
LENGTH 85.2 in.
WIDTH 32.6 in.
HEIGHT 51.3 in.
WEIGHT 206 lbs.
GROUND CLEARANCE 15.0 in.
WHEELBASE 58.0 in.
FUEL CAPACITY 1.8 gal.
SEAT HEIGHT 39.2 in.
DRIVETRAIN
TRANSMISSION 5-speed with multi-plate wet clutch
FINAL DRIVE #520 chain
SUSPENSION Front: 48 mm Kayaba inverted telescopic fork w/adjustable
compression and rebound damping; 11.8 in. travel
Rear: Kayaba single shock w/adjustable preload, compression and rebound damping & separate hi/lo-speed compression adjuster; 12.4 in. travel BRAKES/WHEELS/TIRES
BRAKES Front: 250 mm Floating Disc
Rear: 245 mm Disc
TIRES Front: 80/100-21-51M Dunlop
Rear: 100/90-19-57M Dunlop
RAKE 27.1°
TRAIL 4.6 in
tradesalot
Motorcycles
Jan 2, 2009 09:20 AM
hyperfreezer
Honda Motorcycles
Feb 8, 2007 07:13 AM
bmxdylan01
Oct 26, 2005 12:45 PM
djprettyrick
May 7, 2005 12:42 PM
