Hydro and cable transmission differences
Hey all,
I have a Hydro B18B1 transmission in my car with a blown differential, and wanted to know what, if any, differences there are between the internals of a hydro and cable transmissions as far as the gears/differential go?
*I have found several cable B-series transmissions that would be perfect for what I need, but need to know if the diff's are the same as Hydro ones.*
it appears that all 1990-2001 LS/GS/RS Transmissions, and the Pre1994 GSR's use the same Limited Slip differential, so I assume this means they use the same diff?
The DC GSR's appear to have a different one, while the B16 Trannys appear to have the same diff as the 1990-2001 LS Integras also.
Can anyone verify this?
ramco
Transmission & Drivetrain
Nov 6, 2009 10:42 PM
