Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Lurching transmission......
Old Apr 28, 2008 | 05:22 AM
perfpump's Avatar
Default Lurching transmission......
It seems that while making a "California stop" (coming up to a stop sign and not making a complete stop), my 2008 LX will "lurch" as I hit the gas pedal to go. It happens when I'm going about 3-5 mph and hit the gas to go. It is very annoying and I don't know if it's a normal characteristic of this car. I've tried to soften my foot on the gas pedal, but it only helps sometimes. Or, could there be a problem with the transmission?
Thanks in advance....
Old Apr 28, 2008 | 05:28 AM
2008fijibluesi's Avatar
Default Re: Lurching transmission...... (perfpump)
Is your car automatic or manual. And if it is a manual, what gear do you have it in when doing the "california stop".
Old Apr 28, 2008 | 05:31 AM
perfpump's Avatar
Default Re: Lurching transmission...... (2008fijibluesi)
.....sorry.........it is an automatic
Old Apr 28, 2008 | 05:32 AM
perfpump's Avatar
...and I'm guessing it's in 2nd gear as I'm coming to an "almost" stop.....or maybe I'm catching the car inbetween 1st and 2nd as I'm going for the gas??
Old Apr 28, 2008 | 05:37 AM
Hmm...I don't know then.
My initial guess was that the car was manual
and you were bogging the engine down by going so slow in a gear other than first, but it's an automatic so that's out the door. LOL.
My sister has an '06 EX auto and I've never experienced that problem when driving her car. The transmission should have itself in first going that slow.
I recommend just taking it to the dealer. Let them look it over (under warranty), before it gets worse.
Old Apr 28, 2008 | 05:48 AM
perfpump's Avatar
Default Re: (2008fijibluesi)
thanks....i will take it to the dealer.
Old Apr 28, 2008 | 05:49 AM
Default Re: (perfpump)
You could check the transmission fluid level to see it is at a good level.
Old Apr 28, 2008 | 08:48 AM
ju5tchi11in's Avatar
It's called a "California Roll" not a "california stop"
anyway probably catching car in second and it needs to shift back to first but is having some issues, as said, transmission fluid levels, if not something maybe fishy with tranny.
Old Apr 28, 2008 | 08:23 PM
av911's Avatar
http://www.8thcivic.com/forums....html
Old Apr 29, 2008 | 03:02 PM
Bulli Kid's Avatar
Default Re: Lurching transmission...... (av911)
i think its the drive by wire system.
haxing
Aug 16, 2012 07:27 PM
radialsym
Transmission & Drivetrain
Nov 8, 2008 05:50 AM
ekinshuya
11
Aug 23, 2007 10:27 PM
The-Kid
Aug 18, 2007 01:30 PM
