Buying transmission what to look for??
grab the input shaft and see if it has play, If it does, you have a shot input shaft bearing. Also try rotating the input shaft and check for roughness, which will acount for bearings about to go, or lack of maintence.
From: gravity rides everything...everything will fall, se GA/ne FL
s4c stamp maybe. sounds iffy, but maybe you'll score a perfectly good true s4c trans for $300 and not some busted *** LS. i speak from multiple experiences...people try and be so slick sometimes. why i only pick up transmissions and crack the bitches right open.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gunnerman »</TD></TR><TR><TD CLASS="quote">hard to tell unless you crack it open</TD></TR></TABLE>
hondatuner20
12
Mar 16, 2006 11:42 AM
