OEM Acura integra fog lights, are they plug in and play?
Old Jul 12, 2002 | 05:25 PM
Jsracingintegra
Guest
Posts: n/a
Default OEM Acura integra fog lights, are they plug in and play?
OEM Acura integra fog lights, are they plug in and play? Do they come with directions (w/ illustrations)?
Old Jul 12, 2002 | 05:28 PM
MattD@Stoptech's Avatar
Default Re: OEM Acura integra fog lights, are they plug in and play? (Jsracingintegra)
Yes and Yes...but they do involve some cutting of the black plastic bumper insert...comes with neat templates to help that job though...
Old Jul 12, 2002 | 05:31 PM
95TEG's Avatar
Default Re: OEM Acura integra fog lights, are they plug in and play? (El Pollo Diablo)
yes, the hardest part like he said, is cutting away the black grill portion, other than that, I give them a big
Old Jul 12, 2002 | 05:52 PM
Jsracingintegra
Guest
Posts: n/a
Default Re: OEM Acura integra fog lights, are they plug in and play? (95TEG)
I was told that wires are in the drivers side fender, and they are tucked away. How do I get to them?
Old Jul 12, 2002 | 06:30 PM
Lothar's Avatar
Theres a blue taped hot wire that comes off the drivers headlight harness. Fog light harness plugs in that, use the supplied zip loom tie dealies to secure the harness under the radiator support. I keep blowing fuses on mine now. They quit working, I decided maybe it could be a bad ground. Changed the ground, then began blowing fuses. The plug up front ++ is not very insulated to weather, and mine was all green and fugly.
I think I'm just going to make my own harness up, using a 30amp bosch relay instead of the 27$ mitsubishi 15amp (piece of crap) that is provided. 15 amps seems a bit low for a halogen fog light harness.
Old Jul 12, 2002 | 06:40 PM
Jsracingintegra
Guest
Posts: n/a
Default Re: OEM Acura integra fog lights, are they plug in and play? (Lothar)
Found it. Thank you Lothar and good luck with your ground wire.
DAP97SI
Jun 27, 2010 11:20 AM
Gant
Mar 3, 2009 08:02 AM
Rzoops
Jan 27, 2006 06:51 AM
Surreal
Mar 14, 2004 09:14 PM
elnoyl
Oct 2, 2003 07:52 AM
