'98 Accord alternator ground
I have a '98 Accord EX V6, when I went to replace the alternator today I found that the ground wire was corroded & barely connected to the alternator. Would a bad ground connection damage the alternator over time, or if the ground wire is repaired should the alternator work fine without needing replacing?
godfearer22005
May 18, 2013 02:13 AM
