2005 Acura RL brake project - 4 piston calipers with 13 inch (330mm) rotors
Old Apr 27, 2008 | 12:03 PM
NoSmoking's Avatar
Default 2005 Acura RL brake project for 96 EX - 4 piston calipers with 13 inch (330mm) rotors
Getting together parts for building my Acura RL front brake project for my 96 EX.
[IMG][/IMG]
1. Two 2005 Acura RL 4 piston calipers.
2. Two 2005 330mm Subaru WRX Sti Front rotors, (thanks brakeexpert who told me what to get)
3. 4 (older) 17 inch wheels with 205/40 Nitto tires. (Going to go with 50's later)
4. Have to shorten the hollow bolts that connect the Accord brakelines to the calipers and get new crush washers, but the lines sem to bolt right up.
5. Going to machine heavy angle iron brackets to attach the calipers to the knuckles and use the strongest yellow zinc plated bolts and nuts with lock washers and Locktite.
Tell me what ya think!
Modified by NoSmoking at 12:36 AM 4/28/2008
Modified by NoSmoking at 12:38 AM 4/28/2008
Modified by NoSmoking at 12:42 AM 4/28/2008
Modified by NoSmoking at 12:45 AM 4/28/2008
Modified by NoSmoking at 1:48 AM 4/28/2008
Old May 3, 2008 | 10:10 AM
CL SLeePeR's Avatar
Default Re: 2005 Acura RL brake project for 96 EX - 4 piston calipers with 13 inch (330mm) rotors (NoSmoking
What are you using for the 5 lug conversion. Possibly looking to do this in the future.
Old May 3, 2008 | 11:02 AM
steerh67's Avatar
there is a whole section in the faq devoted to doing a 5 lug conversion. read that if you want to know how to do it.
OP - Are you upgrading the rears at all. also what are you doing about hydraulics, is the stock master cylinder going to be sufficient?
Old May 3, 2008 | 11:13 AM
TheMuffinMan's Avatar
He knows where you live!
Haha I don't think the stock MC will work with this.
dual piston NSX calipers it's fine with, but quad piston? lol I dont think it'll cut it.
Old May 3, 2008 | 01:55 PM
steerh67's Avatar
Default Re: (TheMuffinMan)
lol yeah thats why i asked. its a good idea and a sweet set up, but without the right hydraulics, i think you are going to be disappointed with the performance. try looking into the mc setup on the RL, and see what they're running.
Old May 3, 2008 | 02:10 PM
Also, that's a good point, with the rears at least with this brake setup it may be important to upgrade the rears as well. Maybe at least to NSX rears? I'm afraid with 4piston front and shitty stock rear it probably will offset the like 85% 15% balance or whatever it is.
Old May 4, 2008 | 03:03 PM
CL SLeePeR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steerh67 &raquo;</TD></TR><TR><TD CLASS="quote">there is a whole section in the faq devoted to doing a 5 lug conversion. read that if you want to know how to do it.</TD></TR></TABLE>
RL uses a different bolt pattern. 5/112 After a little search'n on the net. I found that the 05 STi rotors are 5/114. I am well aware of the FAQ section and it's contents.
Old May 4, 2008 | 03:14 PM
Redrilled STi rotors most likely
Old May 5, 2008 | 04:28 AM
BlkChryKord's Avatar
I may venture into something like this on my 6thgen. Already have the 5lug swap done.
Old May 18, 2008 | 02:13 PM
NoSmoking's Avatar
Default Re: (BlkChryKord)
I was going to drill them out for 4 lug. Does anyone know if the GSR master cylinder fits the 96 Accord.
Old Aug 14, 2008 | 11:41 AM
CL SLeePeR's Avatar
Bump
Old Aug 14, 2008 | 01:32 PM
JDM_CD7's Avatar
Post up some good detailed pics !!!
Old Aug 14, 2008 | 01:44 PM
sfcd5's Avatar
i personally dont know if that setup will work. But if it doesnt you should try the acura legend 2 piston brake upgrade.
Old Aug 14, 2008 | 06:46 PM
02 accord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NoSmoking &raquo;</TD></TR><TR><TD CLASS="quote">Tell me what ya think!</TD></TR></TABLE>
I think that if those brackets/bolts fail, you are [freak]ed.
Old Aug 14, 2008 | 06:49 PM
You guys do realize this thread was 3 months old....
Hondasracetech
Oct 7, 2012 03:49 PM
snowblind7x
Dec 21, 2005 09:06 PM
m R g S r
Aug 11, 2005 10:43 PM
ChiBoy
Feb 1, 2002 06:05 PM
