Ran Into A Lil Problem
Old Apr 27, 2008 | 08:59 AM
Bonestock98GS's Avatar
Default Ran Into A Lil Problem
Ok I drove my 88 CRX around the other day and noticed that VTEC kicked in once. So I was like WTF??? All the oil was fine. So the guy I bought the swap from told me that he put in a Civic's speedometer cable and the clip that came with the cable he lost it. So my question is do I have to get an Integra's cable beause the civic's cable is short or do you think I could just get away with the Civics cable and just getting a clip so the cable can stay in. Oh yea this has a B16a swap in it also
Old Apr 27, 2008 | 09:11 AM
Hybridize's Avatar
Default Re: Ran Into A Lil Problem (Bonestock98GS)
Nah you should be fine without the clip.
Just pull the rubber boot back on the cable a bit, then insert the cable kinda firmly, then push the boot back over the cable.
Should be fine with that, it's how I run mine. If you're real worried about it you could throw a zip tie on it.
Old Apr 27, 2008 | 10:37 AM
Default Re: Ran Into A Lil Problem (Hybridize)
I tried that and it pops right back out maybe im not doing it right im bout to go outside and get it done now. Hybridize what part would you put the zip tie around also?
Old Apr 27, 2008 | 11:59 AM
bump
Old Apr 27, 2008 | 12:02 PM
Garage 808 Hatch's Avatar
zip tie it
Old Apr 27, 2008 | 09:16 PM
Default Re: Ran Into A Lil Problem (Garage 808 Hatch)
I know you guys are saying zip tie but zip tie what????? Its a tube that the cable goes in and I dont see where to zip tie it so it can stay in place
Old Apr 28, 2008 | 08:46 AM
taylor1's Avatar
tape it there with duck tape it fixs ever thing
Old Apr 28, 2008 | 12:39 PM
Hybridize's Avatar
Default Re: Ran Into A Lil Problem (taylor1)
You do have a rubber boot on the cable yes? If yes, just zip-tie the boot to the tube. It should be plenty to hold the cable in.
Old Apr 28, 2008 | 01:28 PM
sanimalp's Avatar
$cat /dev/urandom
additionally, that metal tube actually has a notch in it, so you could zip tie the notch and that will grab the body of the cable and hold it. It is exactly how the metal clip works, just with a zip tie instead.
The boot idea is good, i definitely didnt think about that, but it might also explain why my boot was cut vertically when i bought my car.
Old Apr 28, 2008 | 02:03 PM
Default Re: Ran Into A Lil Problem (sanimalp)
Ok I am going to go and try that out. also what if the speedometer still doesnt work?
Old Apr 28, 2008 | 02:40 PM
Aiight still dont know where to zip tie. I placed the cable firmly in also. here is a pic of what I working with here
Eighty-Nyne
Oct 5, 2008 03:19 PM
DOHCRX
Mar 28, 2003 08:22 PM
