trans problems. suggestions needed.
Old Apr 27, 2008 | 06:00 AM
89turboaccord's Avatar
Default trans problems. suggestions needed.
last fall, i just installed a 8 lb flywheel sprung 6 puck and clutch net 3x red pressure plate and a LSD.
The story:
I Was out with a friend doing some pulls. We take off from a light and the car went through 1st and 2nd fine, I pulled 3rd and still seemed fine. I got to the top of 3rd and it felt like the trans exploded(it pop-ed out of third). The trans would not go into any gear. I got the car stopped and still nothing it wouldn't go in to gear.i kill the motor and it would cycle through the gears fine except rev and 5th. i get the car home and pull the trans and open it up.
after 2 hours i couldn't find a dam thing wrong.
I started messing with the linkage and figured something must be bent. i pulled the linkage out of a spare installed it. I set the case on and it shifted fine.
i reinstalled the trans road tested it and all is good driving normally.
i went to do a 1st through 3rd pull. 1st was good 2nd was good and grind-grind 3rd.
the trans goes into 3rd easy at a lower rpm and normal shift.
when i try to shift into 3rd at high rpm and a fast shift or even a high rpm normal shift it will either grind or not go in at all.
all the gears and syncros look fine, there are no chips or excessive wear.
any suggestions?
duugle
Transmission & Drivetrain
Mar 24, 2015 08:17 AM
AcuraTeg32
Dec 16, 2012 07:30 PM
Michael.K.Conte
20
Jun 4, 2010 03:42 PM
dank24
Aug 11, 2006 11:15 AM
[ iLL ] iNt3GrA
Apr 20, 2004 07:03 PM
