engine struggling!! help
Old Apr 27, 2008 | 05:00 AM
jonathanraycamacho's Avatar
Default engine struggling!! help
ok i need some advice with my 92 accord.
it is an auto trans.
when i put it in reverse my car starts to struggle. like its pulsing. what could this mean?
and how to you change out the trans fluid?
jon
Old Apr 27, 2008 | 06:55 AM
yam02's Avatar
Default Re: engine struggling!! help (jonathanraycamacho)
I would advise taking to a tranmission repair shop, possible all other gears are fine but your reverse, b/c it is not good to replace the tranmission fluid yet,because you possible have some metal in the fluid that the tranny is used to.
Old Apr 27, 2008 | 09:43 AM
hondadude's Avatar
There is no such thing as 'old contamination' keeping the trans working.
To change the fluid look under the trans for the drain plug that has a 3/8" square hole in it.
Then after you have it out and the fluid drained, reinstall it. The crush washer is usually okay for a couple uses; refill the trans, thru the dipstick hole, with 3 quarts of Honda Z-1 ATF.
The honda fluid has better cleaning and lubrication properties than generic.
Modified by hondadude at 12:52 PM 4/27/2008
Old Apr 27, 2008 | 11:28 AM
yam02's Avatar
jmanuel
Apr 24, 2014 09:48 PM
bemused
Jul 25, 2013 06:27 AM
Maurice24
Apr 30, 2010 12:39 PM
DIABOLIC8
Jun 11, 2009 01:59 PM
Arkiados
Mar 16, 2007 10:47 AM
