Types of upgraded calipers to put on RSX
Old Apr 26, 2008 | 09:05 PM
The-Kid's Avatar
Default Types of upgraded calipers to put on RSX
Hey there guys. Down here visiting from the Accord side.
I was wondering, I know some brake calipers from Acura cars, such as the Legend with it's 2 piston caliper can be put on the Accord rather easily. Of course with the right rotor size, brackets, and calipers.
I was thinking of upgrading my base RSX's brakes. Please don't ask me why, I just want to. Let's stay on topic. =P I might do it, I might not. Just curious.
I have a 2002 Base RSX. It says in the brochure, the rotor size is 10.3 and the Type-S is like 11.2??? or something. Can I swap the Type-S rotors, bracket and caliper onto my base?
Also I heard about TSX caliper fitting, how does that go?
What other calipers can fit into the RSX? Any 2 piston? With the exception of Brembos. Can TL calipers fit?
Old Apr 27, 2008 | 06:56 AM
WhiteOnRice's Avatar
RSX-S front is 11.8" - https://honda-tech.com/zerothread/2133052
I don't know if the base uses an axle with smaller splines like an EP (and 32mm axle nut) or larger like the Type S (36mm axle nut). Check that out, could change your mind if you needed Type S axles.
Old Apr 28, 2008 | 03:34 PM
typeS_06's Avatar
the type s front brakes setup is a direct bolt on for the base. i just swaped out my stock type s brakes for some wilwood 4 piston brakes and the guy that i bought the brakes from wanted my stock ones and he put them on without having to do anything.
Old Apr 29, 2008 | 09:19 AM
^Good to know.
Should also check if the MC or prop valve is different (utilizing the bigger front rotor).
Old May 20, 2008 | 02:27 PM
The-Kid's Avatar
Default Re: (WhiteOnRice)
Ok so, if I did go with the swap, I would need to have new rotors, and calipers, and also pads. Also the caliper mounting bracket. It seems like an easy swap. What about anything else?
I have the 05-06 RSX-S rims on my RSX base. My braking performance has lessen due to the heavier weight. I am thinking of this swap because of that reason.
norcalem2
Honda CR-V & Element
Nov 29, 2010 11:39 PM
187Chor
Nov 14, 2007 09:07 PM
JCracer723
Dec 2, 2006 12:06 AM
kevEK9
Apr 4, 2003 08:38 PM
