civic starting hard!!!
Old Apr 26, 2008 | 07:56 PM
kryptproductions's Avatar
Default civic starting hard!!!
My civic is starting hard, for example i turn it ovr after i hear the main relay click, and it has a hard starting sound and takes about 4-5 seconds for the first start of the day. i put a new batterie in cuz my old one had 2 dead cells, put a new dist. cap, new plugs and wires, new battery cables, new alternator, new alternator belt... "all these needed replaced" could my starter be going bad??? no check engine light is coming on and it has full power so i think all the cylinders are firing.
just to let you know the engine has 210k miles on it runs awsume
Old Apr 26, 2008 | 08:07 PM
slowcivic2k's Avatar
Default Re: civic starting hard!!! (kryptproductions)
Remove the fuel filler cap, and note any suction sound. Then check the last time the filter was replaced, if ever.
Prime the fuel system by cycling the key every 1-2 seconds to the ON position, don't start it. Do this about 7-10 times, and see if the starting eases. If so, I would replace the fuel filter first, then blame the fuel pump.
Old Apr 26, 2008 | 08:09 PM
Default Re: civic starting hard!!! (slowcivic2k)
alright ill try that and post what i find out thank you
keemerdadreamer
Feb 11, 2010 04:26 PM
dskater4111
18
Aug 5, 2008 10:43 PM
tbaumga
Jul 25, 2007 10:45 PM
chickcheno
Jul 17, 2005 02:18 PM
sivicman
Jan 31, 2004 06:11 AM
