possible transmission problem?
Old Apr 26, 2008 | 05:28 PM
vang's Avatar
Default possible transmission problem?
95 gsr transmission with obx lsd
heres the story... took it apart to put in 5th and reverse syncros, put in obx lsd... works like it should except i forgot to tighten the ring gear (the gear that drives the vss) drives perfect for about 3000 miles... took it apart to fix the ring gear... cleaned everything and put everything in and every bolt where it belongs... installed new clutch...put the transmission back on the car...
the problem,
while engine is running i can shift into 1, 2, 3, 4, 5 WITH OUT pressing the clutch pedal... axes do not spin when shifting into gears... axes will only spin when turned by hand...
ive tired bleeding my clutch, still nothing, thought maybe the clutch was in wrong, took it apart, its installed correctly... figured it might be the transmission, took it apart and still nothing... transmission works like it should... im stumped now...
anyone with any idea what to do please let me know...
Clerique
Transmission & Drivetrain
Jun 9, 2012 09:04 PM
lazyhenry30
Apr 23, 2007 05:44 PM
FastReligion
Jul 10, 2006 05:57 PM
FastReligion
Jul 10, 2006 10:42 AM
jfranknbeans
Sep 14, 2004 10:41 AM
