VSS horror story
Old Apr 26, 2008 | 05:24 PM
Turbo Dan's Avatar
Default VSS horror story
so this is probably around my 8th attempt at wiring up an electronic VSS in my 88 crx dx.
(97 gsr cluster canadian model)
everything on the cluster is wired perfect except for the speedo.
after about the 6th attempt at wiring the vss, i pulled out my electronic vss unit from the tranny and the bottom half of the gear was chewed up a bit, and i found this to be because it wasnt installed all the way in and was a bit ****-eyed.
so i installed it all the way in, got the proper wire connector for the vss, plugged it in, wired it up, positive, ground and vss signal to b16 on ecu, happened to be i think a yellow and red wire.
the 7th attempt i got some odd information and for some reason i read that b11 was the proper vss wire on the ecu, which was a black and green wire.
after figuring out this was wrong i wired it back up to b16 which i believe is the correct one.
and the splice i ran to the orange wire on the cluster harness.
-----here is where the big issue starts
when i fired the car up to test drive it the first time (when i had it spliced into b11 on the ecu) i noticed the tach wasn't working, nor was the temp gauge, and nor was the ebrake light. but the fuel and turn signals seemed to work just fine.
thats when i decided to re check my wiring and reverted to the b16 wire on the ecu.
so can anyone tell me if my cluster is now [freak]ed?
there was no smoke or burning electronics, no blown fuses, and my signals work so the fuse for the cluster is still in action. the gauge lights (dimmer) work correctly.
also as an added bit of info, i have a safc wired up and the tach works correctly on this safc.
everything on the cluster was working up until today.
how can more than one thing on the cluster stop working just like that?
ive been trying to get this speedo working every year since 2004
Old Apr 26, 2008 | 11:47 PM
iheartteal's Avatar
the only thing i can tell u is to try the cluster in another car. im not certain on this but do u think that since the speed sensor is from an obd2 car that it wont work with a obd1 ecu.
ps im just assuming ur using an obd2 vss since the cluster is from a 97 car
Old Apr 27, 2008 | 04:05 AM
thevtecnician's Avatar
Default Re: (iheartteal)
Well I can't really help with your cluster possibly being fried now but here's the wire funsctions at the vss plug. (any vss would pretty much work, even if its an obd2 unit)
Speed sensor wiring
Wire location and function:
Looking at the plug from the wire side with the release button up:
Left wire: ground
Middle wire: +12v switched source
Right wire: speed signal(ecu and cluster)
Old Apr 30, 2008 | 02:13 PM
gringo7718's Avatar
Default Re: (thevtecnician)
VSS Wiring-
Run signal wire to BOTH spedometer AND ECU
GSR plugs
91 CRX PLUG "A" (12 pin Plug)
91 CRX PLUG "B" (8 pin plug)
Another reference:
http://www.geocities.com/speed...r.htm
Modified by gringo7718 at 6:50 AM 7/9/2008
Old May 5, 2008 | 10:01 AM
xalents23's Avatar
Default Re: (gringo7718)
Is the wiring diagram of the VSS connector you supplied the same for a 1992-1995 Civic VSS Speed Sensor?
Modified by xalents23 at 11:11 AM 5/5/2008
Modified by xalents23 at 1:13 PM 5/5/2008
Old May 5, 2008 | 07:22 PM
Turbo Dan's Avatar
the plug i have is from a 92-95 civic and it is identical to this plug, same wire colors and location.
so this picture is of a 92-95 civic vss plug.
i would like to know if this is the same for an ek vss.
in the ek chilton it lists the colors as:
BLK/YEL - Power
BLK - Ground
BLU/WHT - Signal
and it lists them in this order.
does anyone have a picture of a plug harness off of an ek with these colored wires?
edit: thanks for the amazing pics and info though, this is exactly on the right track!
Old May 5, 2008 | 08:04 PM
Turbo Dan's Avatar
here is the ek diagram i think
so if i am reading this right, pin1 is ground, pin 2 is power and pin 3 is signal.
which would be the same as the picture above, just different wire colors.
can anyone confirm this?
Old May 5, 2008 | 08:41 PM
iheartteal's Avatar
thats wat it looks like to me
Old May 6, 2008 | 12:20 AM
JUN.'s Avatar
Im sorry, but thats a horrible wiring... Solder the wires and use heatshrink and start from there.
Old May 6, 2008 | 05:32 AM
Turbo Dan's Avatar
this thread should be added to the FAQ, so much good info in one thread
Old May 13, 2008 | 02:58 PM
ruztie2003's Avatar
Default Re: VSS horror story (Turbo Dan)
help pls i got a avic d3 i dnt know where to hook up the speed pulse signal is that the vss and where can i find it on my 1995 acura integra LS pls send it to my email if theres anyone out there thanks
Old Jun 11, 2008 | 05:50 PM
95dc2teg's Avatar
Default Re: VSS horror story (ruztie2003)
great info!
Old Jun 12, 2008 | 12:25 PM
burnout8488's Avatar
Default Re: (JUN.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUN. &raquo;</TD></TR><TR><TD CLASS="quote">Im sorry, but thats a horrible wiring... Solder the wires and use heatshrink and start from there.</TD></TR></TABLE>
lol seriously... Is that zipties and electrical tape???
Regardless, the info is helpful.
Old Jun 12, 2008 | 03:34 PM
doublethink's Avatar
Default Re: (Turbo Dan)
Yes dan that Blue with White stripe is the output pulse of your sensor.
It should be ran to the ecu as well as the cluster. I once blew up a cluster by incorrectly wiring the fuel guage, i was swapping in an ek si cluster. That SUCKED, for me anyway.
blu/wht is also pretty common amongst other honda/acuras as well of similar year to the EK gen.
BUT NOT ALL of them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ruztie2003 &raquo;</TD></TR><TR><TD CLASS="quote">help pls i got a avic d3 i dnt know where to hook up the speed pulse signal is that the vss and where can i find it on my 1995 acura integra LS pls send it to my email if theres anyone out there thanks </TD></TR></TABLE>
Its always best to use a reference site like the12volt.com or similar when looking for a VSS in any car. Also any Viper/DEI alarm install place should have computer software that gives the vss color and location for almost any car, you just have to know how to ask.
Usually a $20 bill is helpful, and a good attitude.
Also try posting your question on honda-techs audio/electronics section, a lot of installers post in there:
https://honda-tech.com/zeroforum/27
Old Jun 12, 2008 | 08:56 PM
gringo7718's Avatar
Default Re: (burnout8488)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by burnout8488 &raquo;</TD></TR><TR><TD CLASS="quote">
Regardless, the info is helpful. </TD></TR></TABLE>
Come on guys. Its not that bad, I know it doesn't look pretty but its wiring - get over yourselves. The connections are secure and very well insulated. By tapping into the wires, I didn't cut off the original crx plugs or wiring.
(Think about it.....To get heatshrink over this connection, you must cut the original wiring and I was not willing to do this)
Function &gt; Form
Modified by gringo7718 at 3:14 PM 8/6/2008
Old Jun 12, 2008 | 10:25 PM
FernEF's Avatar
well im glad a thread was up in the forum be4 i had to search but anyways i cant get my vss working... im also using a 94-97 gsr integra cluster in my 91 crx.
i have everything wired up correctly that i know of... signal- connected to ecu plug b pin#16 and behind gsr cluster colored orange, power-connected to 12v power behind gsr cluster colored black/yellow, ground- conncted to a ground.. can someone please tell me if i have something wrong or maybe take pics... thanx btw,sorry to thread jack i just what this working
Old Aug 5, 2008 | 02:32 PM
B16CRXT's Avatar
Default Re: (FernEF)
http://flickr.com/photos/64499...etail/
Old Aug 5, 2008 | 02:59 PM
gsrpedro's Avatar
just wire the ground to the car and the power to the power source on the cluster and the signal to the orange pin in the cluster thats it !!! simple as that ur welcome
Old Aug 5, 2008 | 03:44 PM
UfoTofU's Avatar
I put a 94 Integra LS cluster into my 91 CRX, not exactly the same as yours but here is my thread :
https://honda-tech.com/zero...age=1
It took me a lot of research and then some trial and error once it actually came to the installation to get it all right. I had to look up pinouts for both clusters.
From what I remember I used a VSS from a 92-95 Civic. It fit into the tranny no problem but I had to cut off a couple of chunks of it to allow it to clear the tranny mount.
I also remember what I did with the 3 VSS wires was this :
- Ground I grounded to the metal dash frame
- Power I spliced into one of the power wires already going to the cluster
- Speed signal wire I had to split into two and run one to the cluster and one to the VSS signal that went to the ECU
If you need help PM me, I think that I have a wire list that I typed up somewhere, I will see if I can find it for you.
Old Aug 5, 2008 | 09:41 PM
gsrpedro's Avatar
u dont nned to wire the signal cable to the ecu just wire it to the orange cable on ur cluster thats easier
Old Aug 5, 2008 | 09:46 PM
D16SiHatch's Avatar
Default Re: (gsrpedro)
it needs to go to the orange cluster wire, and it also needs to go back to the ecu. without it you will get a check engine light for vss.
InTheLBC20
22
Aug 6, 2010 01:59 AM
90_civic_Si
Nov 24, 2009 06:13 AM
2kTeg
Mar 30, 2005 04:56 AM
0 0 0
Dec 3, 2003 10:30 AM
