only 2 cylinders firing.
Old Apr 26, 2008 | 05:21 PM
civicxxman's Avatar
Default only 2 cylinders firing.
I do not know what is going on only my #1 and #cylinder are firing the wires and plugs are new. could it be the cap or the whole distributor I have no clue what is going on.
Old Apr 26, 2008 | 05:44 PM
DCFerris's Avatar
It could be a number of things i would say make sure there all getting sparks then check your compression but the dizzy might be the problem
Good luck with it
Old Apr 27, 2008 | 08:30 AM
ivan_h22_turboed's Avatar
Default Re: (DCFerris)
sometimes sprak plugs go bad i said change the spark plugs around see if the if it changes something
Old Apr 27, 2008 | 10:54 AM
crxmanifold's Avatar
Default Re: (ivan_h22_turboed)
firing order
Old Apr 27, 2008 | 01:44 PM
Hondasmo's Avatar
Default Re: only 2 cylinders firing. (civicxxman)
Usually when someone does a tune up on a car and it was running fine before the tune up was performed you will find you accidently mixed up the spark plug wires and now the firing order is incorrect .
Old Apr 27, 2008 | 01:52 PM
civicxxman's Avatar
Default Re: only 2 cylinders firing. (Hondasmo)
I replaced the head gasket and it jumped on the first start...... so I think the valves are boogered up.
mynameizstitch
Jun 8, 2009 07:29 AM
97civic07gsxr
10
Apr 6, 2009 07:16 AM
Civic Hybrid
10
Aug 17, 2008 09:35 AM
EblazeK
Aug 4, 2006 01:02 PM
mustbenu
Jan 22, 2004 06:33 PM
