my accord lights dont work after intalling after market radio
i have a honda accord i pu in a radio and my dash klights dont turn on i checked all the fuses and they was all good...can some one help ?????
Hmm, I'd make sure the illumination wire at the radio isn't shorting out, and make sure the fuse is good, usually it will blow. what year accord?
i gaurentee your taillights arent working either and its your small light fuse...check the radio wiring or you WILL keep blowing fuses....they share a common illum. wire....i think its the brown one(on stock harness) which converts to orange....good luck
^wasn't that you that was blowing small light fuses when you first joined? if not my bad, but i remember helping someone with this same problem. and it was the small light fuse (7.5) i had this happen to me after i put my prelude cluster in.
its fo a 99 accord v6..but i took all the fuses out and they was all good and also my check engine light came on ....
its probably unrelated, but have the code checked anyway. how did you connect your wires when you installed your cd player. electrical tape? butt connectors?
Protosouls
Oct 20, 2011 04:29 PM
