what do i need to fix? steering problem ...
whenever i step on the gas, my wheel will turn to the right unless i hold it in place, my car does this a lot and its has prgressivly gotten worse. do i need to replace my ball joints? if not what else could it be
Get your front end checked out by a mechanic. Could also be the tie rod ends; they tend to wear out rather quickly on some of these cars.
It could be the motor or transmission mounts. Check to see if any of them are loose or busted. Also could be caused by a bad tire. Try swapping the front tires and see if it starts to pull the other way.
j0keefe21
Feb 5, 2009 04:25 PM
