d16y8 or d16z6
im goin to be going all motor soon and i was wondering which would be better, a z6 or y8.
currently i have a d16y7 with a y8 head and a y8 tans
The y8 has a slightly better head and intake manifold. Plus you are more likely to find a lower mileage y8 as they are newer. I would at least recommend the y8 tranny.
Do you have they y7 in your car or are you running the z6? That could help. If not I think it's minime time.
Both blocks perform the same, really. Is ODB1 or ODB2 an issue? I'm building a Y8 simply because I need to bass a bi-annual emissions test so I need to stay ODB2. Some think that the Y8 has more of a tendency to spin bearings because the oil pump runs at a lower volume than the Y8. However, the Y8 oil pump can be shimmed and ported or you can purchase a $200 high volume after market pump.
thatseemslegit
Aug 30, 2015 01:45 PM
IVAN93EG
May 14, 2006 11:23 PM
