HELP: Power Lock not working.
Old Apr 26, 2008 | 09:14 AM
UrbanNinja's Avatar
Default HELP: Power Lock not working.
Hi, I have a 99 integra Special Edition (2door) and i believe that this model should come with power locks. However, when i lock my door using the key from the driver side, i can hear the power lock locking the hatch but it will not lock my passanger door... Can anyone tell me what could be the problem?
Thank You.
Old Apr 26, 2008 | 12:59 PM
Audiojb's Avatar
pop your door panel off and make sure everything is hook up. I believe a bar runs to the lock on this inside and on mine it had slipped out. Just a thought
Old Apr 26, 2008 | 04:44 PM
UrbanNinja's Avatar
Default Re: (Audiojb)
do you know if the 99 Special Edition 2door (hatch) has power locks?
Old Apr 26, 2008 | 11:09 PM
Mfoehrkolb's Avatar
Default Re: (UrbanNinja)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UrbanNinja &raquo;</TD></TR><TR><TD CLASS="quote">do you know if the 99 Special Edition 2door (hatch) has power locks?</TD></TR></TABLE>
--- All model integra's have power locks EXCEPT some RS models and GS models. I believe that should be accurate and power locks were only optional for them.
Someone correct me if i gave some false information.
Old Apr 27, 2008 | 02:08 AM
CompanyFlow's Avatar
Do you have an auto lock switch?
Old May 2, 2008 | 12:37 PM
UrbanNinja's Avatar
Default auto lock switch?
my model is SE (special edition) and on the driver side i only have a notch for the hatch.. i do not have a lock switch on the driver side... however when i lock the driver side with the key i can hear the hatch locking itself... and also there is a fuse called "power lock doors" so does that mean the passanger side should have a power lock?
4thgenx42
Aug 24, 2006 06:03 AM
JS2K
Honda S2000
12
Oct 28, 2004 03:49 AM
saanemon
May 26, 2003 11:46 PM
kevinm1981
Jun 3, 2002 07:17 PM
