valve cover problem
i took off my valve cover to put a new valve cover gasket. When i went to put it back on, on three of the five bolt tightened. people told me that it wasnt aligned right. i took it off and saw that its stripped. how can i fix this?
the threads in the cylinder head are stripped??
Best thing you can do is to heli-coil it. You have to drill out the threads, re-tap to a bigger size, and insert a new metal thread.
Get a 6x1.00 heli-coil from your local parts store
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j_scobar »</TD></TR><TR><TD CLASS="quote">Try and run a 10mm tap through it and see if it holds up if not then just drill/tap it to suit an 11mm or 12mm screw. just be careful and take your time.
wtf are you talking about? The threads are 6mx1.00
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by panda_eh2 »</TD></TR><TR><TD CLASS="quote">it's probably the nuts that hold the valve cover on that are stripped. mine did that like a million times. they're just 10mm nuts</TD></TR></TABLE>
it's a single cam and the valve cover is held down by BOLTS, not nuts....come on people.
You're only choice is a new cylinder head or heli-coil really...
</TD></TR></TABLE>wtf are you talking about? The threads are 6mx1.00
hatchii
Nov 29, 2003 08:07 PM
