Thermoswitch Not Connected?
Hi all,
My fan doesn't seem to be turning on, and my overflow bottle is bubbling and overflowing. I have a new ReadyRad Dual Core Alluminum Radiator (so know that shouldn't be the problem for overflow). My Crx doesn't overheat though.....weird. It has a b18a1 LS engine. See pics, because it doesn't appear to me that the thermoswitch is hooked up. If that isn't the thermoswitch what is it?
Thanks in advance
[IMG][/IMG] [IMG][/IMG] [IMG][/IMG]
Thanks in advance
that is the cooling fan switch - just plug it in and see if it works - doesn't matter which wire goes on which post - it is just a switch to ground
WOW! Thanks for such a quick response! Hopefully it will solve the problem. I bled the coolent via the bleeder valve, but that didn't solve the problem. I'll keep all posted
Thanks
Stadler
Thanks
Stadler
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx »</TD></TR><TR><TD CLASS="quote">maybe it needs a new radiator cap? sounds like it is not holding pressure</TD></TR></TABLE>
X2 if its boiling and bubbling but not overheating you probably need a new rad cap
Connecting those connectors worked! Fan kicked on and it no longer bubbles over. Now though when the car warms up(after fan kicks on) the idle bounces and bumps all the way to 1500 rpms. When first starting it is great (perfect idle). I cleaned FITV and IACV. FITV wax ring was way loose. Tightened down, then backed out about 1/8 turn. Any ideas why the bounce when warm?
Thanks again
Thanks again
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stadler »</TD></TR><TR><TD CLASS="quote"> Any ideas why the bounce when warm?</TD></TR></TABLE>usually, it is low coolant level, airlock in the cooling system or IACV not working right - make sure it is completely full of coolant and all of the air is out of the system, start it up and unplug the IACV - if the idle drops down to around 500-600rpm and remains steady, the IACV is the problem - don't forget to rest ECU once you plug it back in because when you unplug it, you will get a check engine light and code 14
Thanks. Tried the IACV and when I unplugged it nothing changed. Didn't even sputter. Seemed like I didn't even unplug it. I know the coolent isn't low, Checked both the radiator and the overflow bottle. Both full. Bled the system again. No change. Weird. I checked the CEL code and it reads 14. Any Ideas?
Forgot to mention I did Reset ECU. Removed Ground for about 15 min From Battery. No difference
Thanks again
S
Thanks again
S
bad-monkey
Honda Motorcycles
Dec 8, 2006 08:10 AM
