help on 95 ej1 brakes
i already did one side. i usually take a screw and screw it into the little holes and push the drumm off. well i tryed to do it on the driver side and it just strip the threads. how do you guys take the drums off. i need to know asap please and thankx.
Get some penetrating lube and hose all around the hub and studs. Tap it with a hammer to help it get in there. Then get out your BFH and hit the face of the drum. Just dont hit the studs or you'll be even more pissed than you are right now.
