Hom much lbs I loose with straight axle??
Old Apr 25, 2008 | 10:29 PM
krystianitr's Avatar
Default How much lbs I loose with straight axle??
HI,
I would like buy straigt axles to CRX 88-91 and can you explain me :
This is it the ultimate in straight axles for your Honda Civic and Acura Integra. Save almost 100 lbs and takes no time at all to install
am I saving almost 100 lbs by changing stock weld for skinnes or just by instaling straigh axle without skinnies??
http://store.titanmotorsports.com/hoacsoreax.html
Thank for reply
Modified by krystianitr at 11:36 PM 4/25/2008
Old Apr 26, 2008 | 05:11 AM
I B BANGGIN's Avatar
Default Re: How much lbs I loose with straight axle?? (krystianitr)
You only save around 80lbs or so and you have to use the straight axle and the skinnies.
Can't use stock wheels with straight axles. They use a spindle mount wheel. (One large nut)
Old Apr 26, 2008 | 05:39 AM
Default Re: How much lbs I loose with straight axle?? (I B BANGGIN)
I have skinnies 4x100 now and my car weight 1700LBS and If I use the straight axles with spindle mount wheel I loose 80lbs???
Old Apr 26, 2008 | 06:00 AM
Your car is pretty light already....street car? If so don't plan it being like that if you get this kit.
Correct, if you use the straight axle and the spindle mount wheel, you loose 80lbs or so. Can't use your 4X100 wheels anymore since there's no studs to use them on.
Rota is right, heard a few things about mounting your shocks back to stock location. Again nothing first hand though.
Old Apr 26, 2008 | 06:07 AM
DaveF's Avatar
you are wrong, the MB products axle is 4x100
Old Apr 26, 2008 | 06:11 AM
Default Re: How much lbs I loose with straight axle?? (DaveF)
Damn I didn't even know MB made them....but in my some what of a defense, he was asking about the one in the link lol.
Old Apr 26, 2008 | 06:21 AM
DaveF's Avatar
pics stolen from Garage 808 Hatch (Craig)
Old Apr 26, 2008 | 06:56 AM
Yes my car is pretty light already
It is my Car
New record of Poland the fastest FWD All motor ET 11.29 no dragstrip no VHT only airport:/
Timeslip
Video
If I sold my light skinnies 4x100 and I use straight axle with the spindle mount wheel I loose 80 LBS I understood good???
Old Apr 26, 2008 | 07:11 AM
Desir Performance's Avatar
I've read the post in the past about fitment issues with the kcc straight axle, but they were from 2yrs ago. Does anybody know if the problems were fixed or if the problems were with every chassi? I know user Jamaican Dave uses kens piece on his ek civic was wondering if they were any fitment issues.
Old Apr 26, 2008 | 09:26 PM
1 2 NV's Avatar
Default Re: How much lbs I loose with straight axle?? (Desir Performance)
what i dont understand is how they get this magical 80lb weight reduction. if i remember right i yanked out my whole rear control arms and stuff and total it didnt weigh 100lbs. are you telling me that the straight axle, wheels, etc weigh only 20lbs? thats not including tires apparently. shocks need to be thrown out as a weigh reduction too cause you reuse them..
Old Apr 27, 2008 | 03:13 AM
1992Si's Avatar
Default Re: How much lbs I loose with straight axle?? (1 2 NV)
^^ I've wondered the same thing...
OP nice car keep it up, it's not easy to do this over there
Old Apr 27, 2008 | 03:16 AM
DaveF's Avatar
Default Re: How much lbs I loose with straight axle?? (1992Si)
i never weighed my straight axles with wheels on it, but i would have to assume its ~~40 lbs. judging from lifting it
Old Apr 27, 2008 | 03:20 AM
1992Si's Avatar
I would guess the biggest weight savings is from the brakes? then the wheel and tire package.
Old Apr 27, 2008 | 03:31 AM
DaveF's Avatar
i dunno. the oem trailing arms/ and either drum or disc brakes are definitly much heavier than the chromoly tubing used in building the straight axle. imo, probably the wheel tire package is a close second to the chromoly VS. oem trailing arms. i dont think there is but a "maybe 2 lbs" savings from the calipers. i know these rotors for the spindle mounts are heavy, or at least the ones i have seem heavy.
Old Apr 27, 2008 | 03:54 AM
1992Si's Avatar
I know the calipers and rotors for our Strange spindles were very light. I would almost say the spindles alone weight weigh = to coilovers with springs.
They sat here on the floor for a while in Feb, you would have thought I would have weighted them. DUH.
Old Apr 27, 2008 | 05:47 PM
jjspec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaveF &raquo;</TD></TR><TR><TD CLASS="quote">you are wrong, the MB products axle is 4x100 </TD></TR></TABLE>The JJSPEC Racing straight axle also uses the 4X100 bolt pattern. It also can use stock brakes or aftermarket.
Old Apr 27, 2008 | 07:00 PM
1 2 NV's Avatar
Default Re: How much lbs I loose with straight axle?? (jjspec)
who the hell is jjspec? never heard of them. website is broke too.
Old Apr 27, 2008 | 07:30 PM
jjspec's Avatar
Link is messed up. Go to http://www.jjspec.com We have a Hot Rod car
Old Apr 27, 2008 | 08:17 PM
Garage 808 Hatch's Avatar
Damn Dave, you beat me to it, ya the old MB straight axles were 4x100. unfortuneately it was already on the car when i bought it, so i dont know the weight differences. but the pice is pretty light. im guessing most of the weight loss is in getting rid of the trailing arms, and all the substructure.
Old Jul 11, 2008 | 01:25 AM
Default Re: How much lbs I loose with straight axle?? (Garage 808 Hatch)
HI
It Is my straight Axles by Kens kustom chassing.
It just came to Poland and I put It and I lost weight 58 LBS not 100 lbs without skinnies
Skinnies Weld
Old Jul 11, 2008 | 11:28 AM
Nice did you install it yet? What shocks and springs are you going with?
Old Jul 11, 2008 | 04:07 PM
Sir2egk's Avatar
i have the kens kustoms solid axle and from my muscular arms i can tell that theres a big difference
with front on jackstans, i can lift my rear end all by myself and thats with tires and brakes and all
i have a hard time on my friends car
its on an eg hatch
as for fitment, for some reason, mine sit a little further forward and i cant really slam it unless i cut off a chunk off of the frame rail on both sides
Old Jul 11, 2008 | 04:18 PM
DaveF's Avatar
Default Re: How much lbs I loose with straight axle?? (Sir2egk)
yea, you need to notch the frame to make it sit right with the straight axle.
Old Jul 11, 2008 | 04:26 PM
Sir2egk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaveF &raquo;</TD></TR><TR><TD CLASS="quote">yea, you need to notch the frame to make it sit right with the straight axle. </TD></TR></TABLE>
i got the omni drag rears but cant drop it more, the stuts too stiff and car is too light. if i loosen mine all the way, still too stiff and springs are just sitting free
what struts can i swap for?
and what do you have in front? any pics?
i see you parting out, how much you want for the rears? PM me
Modified by Sir2egk at 7:35 PM 7/11/2008
Old Jul 11, 2008 | 05:11 PM
DaveF's Avatar
