Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
One touch driver window malf.
Old Apr 25, 2008 | 08:56 PM
Nighthawk R18's Avatar
Default One touch driver window malf.
Yesterday i swerved to avoid hitting a deer and went into a pile of soft dirt. soft enough to where i had no scratches or kind of damage. but the impact was so hard that my battery terminals got disconnected. got out my 10mm and tightened them up and proceeded driving. After that i noticed my one touch wouldnt work.
The window wouldn't roll all the way down but it still works and i just have to hold it down. any idea what could be wrong? is there a fuse i can check for somewhere? i checked the fuse chart inside the box and under the kick pannel with no luck.
any help please? thanks
Old Apr 25, 2008 | 09:12 PM
fg2si!kid's Avatar
New User
Default Re: One touch driver window malf. (Nighthawk R18)
there are two fuses for the driver side in the under dash fusebox number 10 and 26. maybe your sliders need to get re adjusted
Old Apr 25, 2008 | 09:22 PM
RICO_'s Avatar
NO MERCY!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fg2si!kid &raquo;</TD></TR><TR><TD CLASS="quote">there are two fuses for the driver side in the under dash fusebox number 10 and 26. maybe your sliders need to get re adjusted
OP while you're at it check your wheels and tires.....an impact that hard could possibly bend a wheel or put a knot in your tires.
Old Apr 25, 2008 | 09:31 PM
fg2si!kid's Avatar
New User
also if you up for it hear is a quick scan i made on a switch diag you will need a jumber wire or a DMM
http://i60.photobucket.com/albums/h34/em2kid/c.jpg
http://i60.photobucket.com/albums/h34/em2kid/b.jpg
Old Apr 25, 2008 | 09:41 PM
Default Re: One touch driver window malf. (RICO_)
checked, thanks sikid
both fuses are fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RICO_ &raquo;</TD></TR><TR><TD CLASS="quote">
OP while you're at it check your wheels and tires.....an impact that hard could possibly bend a wheel or put a knot in your tires.</TD></TR></TABLE>
checked, thanks rico. all wheels and tires are okay, i just have some grass and dirt inbetween my hubcaps. good thing my enkeis are sitting safely at home. alignment is also the same. hasnt changed.
after all this i realized my battery is leaning down. my coolant tank was not attached and my AEM cai is also leaning because theres a mount that connects it to the battery tray. this could be more serious than i thought
Old Apr 25, 2008 | 09:44 PM
RICO_'s Avatar
NO MERCY!
Better take it into the dealership for a thorough inspection.
Sometimes hits like that won't cause problems right away but can creep up and bite you in the *** a little later on down the road.
Old Apr 26, 2008 | 01:23 AM
ekb16's Avatar
u have to initialize the one touch function for that window...
1. key ON or Engine running
2. roll window all the way up
3. hold the switch down to roll the window all the way down and HOLD it for 2-5sec.
4.roll it all the way up and hold it for another 2-5sec.
5.. roll it all the way down and hold it again for 2-5 sec.
6. u should here a very light click of somekind from the window reg. and it should be reinitialized..
Old Apr 26, 2008 | 01:49 AM
Default Re: (ekb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb16 &raquo;</TD></TR><TR><TD CLASS="quote">u have to initialize the one touch function for that window...
6. u should here a very light click of somekind from the window reg. and it should be reinitialized..</TD></TR></TABLE>
holy crap dude. that worked!!! didnt know it was that simple.
thanks ekb!!!
Old Apr 26, 2008 | 06:47 AM
high_revs's Avatar
Default Re: (ekb16)
dammit you got to it before me...yeah all that you needed to do was reprogram the window..
Old Apr 26, 2008 | 08:14 AM
elohel's Avatar
Default Re: (ekb16)
Bah you beat me to it! Same thing happened to me a year ago (well not same circumstances, but I got a thing replaced in my window and I lost the function) so I had to do the same thing.
Old Apr 26, 2008 | 12:19 PM
ekb16's Avatar
hahha sorry guys..after workin at honda u kinda get alot of these problems after ppl disconnected their battery
EDWINV00SI
Jan 19, 2011 08:39 AM
jlowellintegra
Nov 25, 2010 04:23 PM
tiptopEBPcivc
12
Aug 15, 2009 03:26 PM
dcdcdc
May 9, 2008 08:23 PM
DFW
Jan 31, 2006 08:26 PM
