Bottleneck Leak?
Old Apr 25, 2008 | 07:01 PM
badboyr66's Avatar
Default Bottleneck Leak?
I have this leak coming from a outlet that I am not using. I capped it off but it leaks a bit. Is there another bottleneck I could use other than this one that would eliminate that nipple?
Old Apr 25, 2008 | 09:24 PM
sorrule's Avatar
can't really tell but it looks like a GSR P72 head, I think you may have your water neck turned the wrong way. I there is supposed to be a bleeder valve/ screw in the place you are trying to block off. But like I said I can't really tell.
Old Apr 25, 2008 | 10:06 PM
badboyr66's Avatar
Default Re: (sorrule)
No that is a B20 head. There is no bleeder there.... thats is where a coolant line was that is not needed on this car
Old Apr 26, 2008 | 07:39 PM
funk.regulator's Avatar
I recommend just getting a new nipple and putting the clamp a bit further down.
Old Apr 26, 2008 | 11:52 PM
p10hlm's Avatar
Default Re: (funk.regulator)
your transmission is missing its vin number
Old Apr 27, 2008 | 09:15 AM
badboyr66's Avatar
Default Re: (p10hlm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by p10hlm &raquo;</TD></TR><TR><TD CLASS="quote">your transmission is missing its vin number </TD></TR></TABLE>
oh crap man.. you serious?... oh well.
Anyone else?
Old Apr 27, 2008 | 10:59 PM
welfarepc's Avatar
maybe recirculate it? not sure why its building so much pressure there.
tap it and screw a plug in
Old Apr 28, 2008 | 01:03 AM
badboyr66's Avatar
Default Re: (welfarepc)
No where to really tie it back in. There is really not that much pressure it is just a soft rubber cap. I might have it lopped off and welded I guess
Old Apr 28, 2008 | 05:06 AM
sorrule's Avatar
if you really don't need it just fill it with like JB weld or something and then cap it off just to make sure
Old Apr 28, 2008 | 11:49 AM
badboyr66's Avatar
MM I will get it welded. I do not trust JB to go through those heat cycles
isaacEK
Sep 1, 2007 09:47 PM
TorquelessB16
Jun 9, 2006 07:29 AM
seeeya04
Dec 6, 2005 11:48 AM
EG6R
11
May 11, 2005 08:05 AM
4speed
11
Dec 6, 2003 01:06 PM
