TYPE R Transmission in EF
Old Apr 25, 2008 | 04:41 PM
MikeLuder's Avatar
Default TYPE R Transmission in EF
ey guys im a prelude guy workin on my hatch so don't clown, i searched couldnt find my answer! x)
I gota 94LS B18A motor im tryin to put in my hatch.. but i need a transmission and am dead set on a type R.
htmotors & they got a 97spec they will part out for me but i need to make sure it will work...
i know it will bolt up, but i thought i read somewhere that it has issues with the crossmember or something? And the Speed Sensor Issue? I have a type R speedsensor i got but didn't know if it will work with my wiring harness & computer. The car is staying Obd0
Also, i will be buyin the hydro conversion kit from innovative for the mounts..
anybody done this please give me some direction! thanks
Old Apr 26, 2008 | 01:34 AM
fourthgenhatchB17's Avatar
Default Re: TYPE R Transmission in EF (MikeLuder)
It will work just fine. Just be sure to get a mechanical VSS (either from a 90-93 teggy or even a 88-91 d series one will work) to replace the electronic one that comes with the ITR trans. I dont know of any issues with the front crossmember...
Old Apr 26, 2008 | 02:38 AM
m1k3typer's Avatar
you have make the holes on the t bar larger for the hydro trans bolts oh and you can use the mechanical vss thanks to hondas part cross compatiabilty
Old Apr 26, 2008 | 03:06 AM
gibsanez's Avatar
Default Re: (m1k3typer)
You could just get a 92-93 GSR transmission, it's cable.
Cable YS1 on the left, 95-97 JDM R trans on the right.
http://www.fatboyraceworks.com...are=1
Old Apr 26, 2008 | 10:13 AM
MikeLuder's Avatar
Default Re: (gibsanez)
Believe I have both the D series Vss & TypeR VSS. so I can just use the D series? that works..
my reasoning with the type R, is I can't find a decent cable transmission any where! the type r is the best one iv found.. i'm not tryin to pay for junk in my hatch. i'd take a quailty ys1 if i could get it.
SilverEF88
Northwest
33
Jul 23, 2012 06:48 AM
teefunk01
May 25, 2009 05:59 PM
89_slovic
Jan 20, 2006 05:40 AM
Mr Furball
Aug 14, 2002 10:29 AM
