New PB 10.32@141.5
Took the car to the track on Sunday. Track wasnt hooking well. Temp was cool for once and had a slight tail wind. Only change was the dual walbro pump setup(NO POWER BUT A LITTLE PEACE OF MIND). On my last pass I tried to turn up the boost from 25 to 27 psi and the clutch started to slip. Not bad for a CM FX300 !!!! Ill be installing a new clutch and adding some boost and looking for that 9sec pass. This car has treated me so well. I drive it 50min each way to the track. Not bad for a mostly stock build except rods and pistons . Im even on stock axles:up:
VIDEO---
92 Civic Hatch
24.5X8.5X13 MH
setup-
Block is a Fresh K24 block from Honda
CP 9:1 compression STD bore swaine tech coated
IB H beam rods
Golden Eagle head studs
factory rod and main bearings.
Stock k24 oil pump w/ upgraded spring for increased oil PSI
Head is stock Type S w/ stock cams
RBC manifold
EP3 trans (5spd) w/ OBX LSD
Turbo Kit is FULL RACE
Stage 3 GT series
GT35R .82a/r vband housing
Tial 50mm BOV
Tial 44mm wastegate
PWR/Full Race vertical feed intercooler
2.5" charge pipes
RC 1200cc injectors
Kpro
AEM 3.5 bar map
Dual intank 255 pumps (fullblown kit)
VIDEO---
92 Civic Hatch
24.5X8.5X13 MH
setup-
IB H beam rods
RBC manifold
Stage 3 GT series
Tial 50mm BOV
Tial 44mm wastegate
2.5" charge pipes
RC 1200cc injectors
Kpro
AEM 3.5 bar map
hey man, its Randy out in Tampa. Give x a call at Brotherz racing, they have a competion clutch twin disk in stock for a k. then she'll be ready for as much boost as you want, lol!!
Modified by poorboy44 at 1:10 PM 4/26/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by na200whp »</TD></TR><TR><TD CLASS="quote">Thanks
Going back to the track on May 10th. </TD></TR></TABLE>
Good luck homie. What does your car weigh in at now?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by na200whp »</TD></TR><TR><TD CLASS="quote">I drive it 50min each way to the track. </TD></TR></TABLE>
Best feeling in the world driving your car home after hitting a new pb.
